  4. Offline maps
Offline maps
24 Posts 8 Posters 442 Views 1 Watching
  • Ian foster 0
    Ian foster 0
    Ian foster 0
    Hi do you know when roughy the offline mode will be implemented? I am travelling Europe at the end of May and parts of Switzerland and dolomites I think we will struggle for phone signal and will have to rely on an offline mode , hopefully I can use the beta app ? . Iโ€™ve just got back from a weekend around snowdonia in Wales and phone signal dropped on me a few times leaving the navigation stuck in the last place I had signal.
    Thanks In advance
    • Ian foster 0 Ian foster 0
      Thanks In advance
      @Ian-foster-0 will be implemented for sure before the end of May! ๐Ÿ™‚
        Thanks In advance
        @Ian-foster-0, Next already makes use of the offline maps if you download them, as it stands. It is just for starting a route, the calculation needs an active internet connection. Once you are underway, the offline map will be used. That could of course be a problem if you need to restart your route underway for whatever reason. But in general it will work. (tip: keep the current Navigation App installed, with downloaded maps...)
        Ian foster 0 Greg Meekings 0 2 Replies Last reply
          Ian foster 0
          Ian foster 0
          Ian foster 0
          @Con-Hennekens Thanks I downloaded the current nav app yesterday and downloaded uk&wales as a backup, will test the โ€œnextโ€beta app then in a couple of weeks with uk maps downloaded when Iโ€™m next out on the bike ๐Ÿ‘
            Greg Meekings 0
            Greg Meekings 0
            Greg Meekings 0
            @Con-Hennekens I've successfully downloaded UK and Spain. However, the 'offline navigation' toggle (account>navigation settings>functional) remains greyed out and unavailable. Are you suggesting that despite this the app uses the downloaded map?
            • Greg Meekings 0 Greg Meekings 0
              @Greg-Meekings-0 That is correct. The offline maps will be used! ๐Ÿ™‚
              You however still need internet to calculate the actual route. Once that is possible too (working on it as we speak) - the offline preference switch you mention can be used.
              Greg Meekings 0 1 Reply Last reply
                @Greg-Meekings-0, What Corjan says.
                Offline navigation and offline maps are separate things.
                  Greg Meekings 0
                  Greg Meekings 0
                  Greg Meekings 0
                  @Corjan-Meijerink Thanks - understood.
                  • Theo Lammerts
                    Theo Lammerts
                    Theo Lammerts
                    Trying to download maps, but then I get the following message.IMG_5495.PNG IMG_5496.PNG
                    • Con Hennekens
                      I get this error also quite often. In the meantime I have downloaded Belgium and Luxemburg, but downloading Germany and the Netherlands seems impossible, there is just ZERO progression.
                      I think I had some maps downloaded prior to the update. Is it possible I need to delete those old downloads because they are not recognized, but that they are conflicting with the new downloads?
                        @Con-Hennekens that should not be required but we are aware the offline maps state management isnโ€™t at the level we need it to be ๐Ÿ™‚
                          @Corjan-Meijerink, I took the cow by the horns (reference to https://www.facebook.com/MakeThatTheCatWise/) and deleted cache and data for the app. Then I went back in and tried downloading the Dutch map. It doesn't download (keeps circling, no progression, also not after a long time). Then I took my other phone. There were already some maps downloaded prior to the update and they were shown as present. I tried downloading another map that wasn't already downloaded. It failed, as failed the download of the Dutch map after deleting it (by pressing the X). I stopped the app, cleared cache and data, and tried again. Exactly like the other phone, no downloads, no progress, keeps circling.
                          I suspect something to be wrong with it, since the Friday update.
                          One is Android 10 on a CAT S52, the other is Android 12 on a Huawei P30 Pro
                          Both plenty of memory left and no SD cards in play.
                          MarcM 1 Reply Last reply
                            MarcM
                            MarcM
                            MarcM
                            @Con-Hennekens Same experience, deleted the app, and reinstalled the app again, problem solved
                            • Con Hennekens
                              Huh... I am trying this download at work now, and it seems to succeed...
                              Is it possible there was a service interruption at the server end yesterday?
                                @Con-Hennekens not very likely ๐Ÿ™‚
                                I actually had to update my own offline maps yesterday (NL, DE, BE, LU) and it took quite long, the lack of progress was disturbing but it completed quite well eventually ๐Ÿ˜‰
                                UltraStar 1 Reply Last reply
                                • Patrick 3a
                                  Patrick 3a
                                  Patrick 3a
                                  I had also problems with downloading some maps. But than I realized that I activated the offline-mode. When I deactivated the offline-mode, it started to download the maps
                                  • Patrick 3a Patrick 3a
                                    @Patrick-3a thanks for mentioning ๐Ÿ™‚ This makes me realise I might have forgotten an offline mode check there ๐Ÿ˜“
                                      @Corjan-Meijerink, I don't consider offline mode set to on relevant to being able to download maps. I think it is better to check for internet connection, en warn that any download will be queued until an internet connection is available.
                                        @Con-Hennekens You might not consider it relevant ๐Ÿ˜‰ The HERE SDK disagrees. If offline mode is enabled, you simply cannot continue / start downloading offline maps as the SDK isn't allowed to connect to internet at all.
                                          @Corjan-Meijerink, Well, then I think you should email them about their "brilliant" idea... ๐Ÿ˜‰
                                          Theo Lammerts
                                          Theo Lammerts
                                          MarcM
                                          MarcM
                                          UltraStar
                                          UltraStar
                                          Patrick 3a
                                          Patrick 3a
                                          Greg Meekings 0
                                          Greg Meekings 0
                                          Ian foster 0
                                          Ian foster 0
                                          • Strange translation
                                          • Shared toggle switch
                                            martin-phogel.de
                                            martin-phogel.de
                                            10.5k
                                          • Undo/Redo tool is hidden
                                          • Crazy routing
                                          • A07 Shared Route Collaboration โ€“ Change Log?
