  4. Opening route causing ‘er ging iets mis’ error
open route
7 Posts 4 Posters 84 Views 1 Watching
  • Ad Bouman
    Ad Bouman
    Ad Bouman
    wrote on last edited by Ad Bouman
    Hello,
    I’ve created a route on my MacBook, called ‘Hemelvaart 2023’. It’s a public route. Opening it on my iPhone on the MyRoute-app I get the error ‘er ging iets mis’. If I open the route on the browser on my iPhone, it opens ok.
    • Ad Bouman Ad Bouman
      Hello,
      @Ad-Bouman This probably means the app cannot find your current location or there is no route from your current location to the start of that route.
      Please check your location permissions and verify the start of the route is reachable from where you are 🙂
      Ad Bouman 1 Reply Last reply
        Ad Bouman
        Ad Bouman
        Ad Bouman
        @Corjan-Meijerink I have double checked. It works ok with other routes that I created.
        This is my setting :
          @Ad-Bouman, Can you share a link to that route (and set it to public)?
            Ad Bouman
            Ad Bouman
            Ad Bouman
            This is the link: https://www.myrouteapp.com/route/open/7065391
            The route is public.
              @Ad-Bouman
              Hello Ad,
              This is probably due to several reasons:
              Route Length: 3,394 KM
              Divide these into day routes
              Closed passes
              See: https://forum.myrouteapp.com/topic/3343/here-issue-regarding-seasonal-closures?_=1677216193902
              Placement of waypoints, see picture
              Always place waypoints on the road
              • Ad Bouman
                Ad Bouman
                Ad Bouman
                Hello Hans,
                I've split the route in 2 parts and indeed, I can now load them in the app also. I've also 'disabled seasonal closures' in the toolkit. However, that in itself didn't resolve the issue, I really had to make the routes smaller. (By the way, I usually break the route up in 'day' parts, when I'm ready with it. While I'm working on it, I like to keep it as the whole route, so it's easier to change the daily stops, in case we end up with 1 long day, or if we want to bring in a relax-day. I'll see if I can work with the 'add route' option, to get more then 1 day in the view. At least I know now that I have to split the route into smaller parts, before I can use them in the myroute-app.
                Thanks for your help.
                Ad.
                Ad Bouman
                Ad Bouman
                  Lluís Casals
                  Lluís Casals
