  3. Events / MRA Navigation
3 Posts 3 Posters 633 Views 2 Watching
  • Mopetenpit
    Mopetenpit
    Mopetenpit
    I have a suggestion, possibly there will be a positive echo...😊
    When you add routes in the "Events" section, a copy of the original is placed in the "Events" section. This is good. For me, the possibility of linking a route would also be a good option.Advantage (subjective): if I make changes to a route, the changes are also immediately visible to my fellow riders in the "Event" area. I can of course share the route - without using "Event" - with my fellow riders by publishing my route as well, but using "Event" has advantages as well.
    Further suggestion / question: with Garmin devices (I do not know all) I can put the track in the background when driving the route. Would not this also be a good addition for MRA navigation?
    Peter
    • Mopetenpit Mopetenpit
      Peter
      @mopetenpit I totally agree with you, having routes in the events linked, instead of copied. Absolutely terrible, but one gets used to it 😞
        I do like the fact that a copy is made that is shared in an event.
        And it does indeed take some getting used to.
        With regard to making the track visible in MRA navigation, this may be included in further development.
        Mopetenpit
        Mopetenpit
          11.9k
        • F004 MRA Navigation Error
        • Probleem met eigen Stay
          Albert van den Elsen
        • POI functie 'strict'
