  3. Transfering Routes to Garmin XT - SD Card
6 Posts 3 Posters 1.4k Views 1 Watching
  • John Forrester
    John Forrester
    John Forrester
    Hi, Is it possible when using the export function of MRA to my Garmin XT to store the route on to the SD card directly? Am I missing how to do it or is it not possible.
    Thanks any advice appreciated. John
    • John Forrester John Forrester
      @john-forrester
      Hi John, by default the gpx file goes to the XT.
      What you can do is: Save the route as (gpx 1.1 (Route, Track and POI)
      or
      Do NOT enable the MTP setting Mass Storage Device, then the XT will not be seen as a disk, but your SD card may be.
      If that does not work, then export the route via the connector and transfer the gpx file via the explorer.
      This for a Windows PC!
      For a Mac it is slightly different, search the forum if you have a Mac.
      John Forrester AWDC LAO 3 Replies Last reply
        @john-forrester
        or
        John Forrester
        John Forrester
        John Forrester
        @hans-van-de-ven-mra-master
        Thanks for that, I think i Had it set to mass storage option, I will try it they way you suggest.
        Thanks. John
          @john-forrester
          or
          John Forrester
          John Forrester
          John Forrester
          Just re tried it and my routes .tracks etc are on the SD card. Thanks. John
            @john-forrester
            or
            @hans-van-de-ven-mra-master A Mac from Apple is different, I always copy my files .ITN and .GPX(1.n) directly to the right map on the SD. ( simple and always working )
            • John Forrester
              John Forrester
              John Forrester
              Hi, thanks for all the help its now sorted. Cheers. John
              • HABVEN aka MrMRA HABVEN aka MrMRA locked this topic on
              John Forrester
              John Forrester
                11.9k
              • F004 MRA Navigation Error
              • Probleem met eigen Stay
                Albert van den Elsen
              • POI functie 'strict'
