  3. Viapunt no warning
Viapunt no warning
9 Posts 4 Posters 1.5k Views 3 Watching
  • Dolomitiundefined Offline
    Dolomiti
    Is it normal that in the Navigation app the viapunt is not mentioned. I.o.w. should't you get a warning that you're approaching a viapunt? And even better that it reads out the name of the viapunt? The problem is that if you're not looking at your device you may drive by without noticing it.
    Hans van de Ven MR.MRAundefined PAD 0undefined 2 Replies Last reply
    • Dolomitiundefined Dolomiti
      @dolomiti
      Yes, that's normal, you won't get a warning and the point won't be spoken
        PAD 0undefined Offline
        PAD 0
        @dolomiti Might there be a degree of confusion over terminology here? I would expect via points to be announced and shaping points not to be. Could you provide a link to one of your routes in which points you want to be announced aren’t being, please?
        Dolomitiundefined 1 Reply Last reply
        • PAD 0undefined PAD 0
          Dolomiti
          @pad-0 Here is the link to the route I tested. I was expecting for point 3 to get an announcement. https://www.myrouteapp.com/nl/social/route/5474795?mode=share
          Stefan Hummelinkundefined 1 Reply Last reply
            @PAD-0 @Dolomiti Neither of the two different waypoints are announced in MRA Navigation. The announcement functionality originates from dedicated Garmin satnavs as I understand it.
            MRA Nav does not include any type of waypoint announcement.
            PAD 0undefined 1 Reply Last reply
            • Stefan Hummelinkundefined Stefan Hummelink
              PAD 0
              wrote on last edited by PAD 0
              @stefanhummelink Down to a combination of my having very largely given up using Navigation some time ago due to it’s amazingly widely varied unreliability, along with my tendency to rarely use via points, maybe my mind is playing tricks, but I could have sworn it did announce via points. I am very open to being mistaken though.
              If Navigation doesn’t currently announce via points (and never has) then that’s yet another massive failing to attribute to the app. In fact, I’d put it in a category called ‘dumbass’! It might as well just use shaping points.
                @pad-0 From my knowledge the via points were not introduced in MRA Routeplanner for use in MRA Nav perse. Instead it was intended for use with the garmin devices. Via points in MRA navigation are treated differently from shaping points in via points being not automatically skipped by the auto skipping algorithm.
                Now, before some users start commenting that this functionality in its entirety does not function correctly, the intent of the algorithm is as I wrote.😋 And that's where the distinction between both points arises.
                  Dolomiti
                  @stefanhummelink @PAD-0 all great that we can distinguish between them and I understand this was originally done for the Satnavs. Now it's time to take 1 step further and use the advantage that you can distinguish between them and make a little annoucement 🙂 in the MRA Nav.
                    @dolomiti said in Viapunt no warning:
                    I could not agree more! 😃
                    PAD 0undefined
                    PAD 0
                    Dolomitiundefined
                    Dolomiti
                    • Segmentation
                      Lenny Oundefined
                      Lenny O
                      Big Al 1undefined
                      Big Al 1
                      RetiredWingManundefined
                    • Onbekende fout, 3 problemen
                      Klompenmaker1undefined
                      Klompenmaker1
                      undefined
                      Thomas Neumeyerundefined
                      Thomas Neumeyer
                      1.7k
