  4. Issues since the 5.1.0-462 update / Crashes and lag
99 Posts 22 Posters 21.9k Views 9 Watching
  • Peter Zehentreiter
    My DMD-NOR7E is being delivered tomorrow 😀
    Then I’ll test straight away to see if the crashes might be down to the hardware.
    BMW R 1250 GS
    DMD-NOR7E 7"
    SPC Universal mount
    Motorola Edge 40 "offline"
    Sena SLR 3
    Sena 50 R
    Marinus van Deudekom Aiello antonino 2 Replies Last reply
    • Roland Busenhart
      Roland Busenhart
      Roland Busenhart
      Today: 340 km in just under 6 hours from Hamburg to Eschwege, near Kassel—many sections of the route required frequent navigation instructions (very less highway, mostly country roads). Everything went smoothly; the track log could be saved.
      Using MRA on
      BMW R1300GSA with Carpuride CarPlay
      Ducati Monster 937+
      Honda X-ADV750
      VW Golf R with CarPlay
      VW Crafter/Eribacar600 with Carplay
        @Peter-Zehentreiter good luck with your new device.
          @Marinus-van-Deudekom Thank you
          BMW R 1250 GS
          DMD-NOR7E 7"
          SPC Universal mount
          Sena SLR 3
          Sena 50 R
            @Peter-Zehentreiter If it were the hardware's fault, we should all change devices...🤦🏼‍♂️
              @Aiello-antonino ✌️😎
              BMW R 1250 GS
              DMD-NOR7E 7"
              SPC Universal mount
              Sena SLR 3
              Sena 50 R
              • Andries
                Andries
                Andries
                @peter-zehentreiter just back from a 5 day trip in france. Have to mention i did 2 week ago update to 5.2.0-474 and first day everthing working nice for a 10h trip.
                • Andries Andries
                  @Andries You said everything was fine on the first day – how were the other days?
                  Did you use online or offline navigation?
                  BMW R 1250 GS
                  DMD-NOR7E 7"
                  SPC Universal mount
                  Sena SLR 3
                  Sena 50 R
                  • Andries
                    Andries
                    Andries
                    @peter-zehentreiter
                    I have the Nor7E for about couple of mounths and this is a great device!! Coming from a chigee AOI6 and it's a huge improvement.
                    2 weeks ago i did the update to 5.2.0 and did not experience any troubles on a trip for 6h.
                    This week a went on a 5 day trip to france and for day 1 everything was working properly.
                    Day 2 the problems starting to appear. After 1h riding i seen the lag on the navigation.
                    If i touch the screen it doesn't respond directly. I had to wait and then i could move the map. Same if you wan to press an icon you had wait for 2s.
                    Temperatur was 32°C outside.
                    A friend of my was driving with iphone 15 pro max with chigee AOI6 mention the same problem but even worse!
                    The first thing that i thought was the high temperature sow i ask my friend if he could put his phone in his jacket so it can cool down. For him this was the solution.
                    The only thing that i could do is make GPX and used the DMD app that is installed on the Nor7E.
                    The DMD app worked flawlessly and smooth in combination with the Silverfox C1.
                    Today I am trying in my office the MRA navigation and there is lag when i move the map or zoom in/out.
                    Please let me know how it works for you.
                    Regards
                    Andries
                    • Andries Andries
                      @peter-zehentreiter
                      Regards
                      Andries
                      @Andries Thanks for your detailed report.
                      At least you didn’t experience any navigation dropouts, which I find quite remarkable.
                      My device is still with DHL and will be delivered on Monday… I’ll definitely let you know how it performs for me.
                      Did you connect the C1 via Bluetooth, or did you connect the controller using a cable?
                      BMW R 1250 GS
                      DMD-NOR7E 7"
                      SPC Universal mount
                      Sena SLR 3
                      Sena 50 R
                      Andries 1 Reply Last reply
                        Andries
                        Andries
                        Andries
                        i have connect it via bluetooth.
                        Don't forget to change the setting to F1 and not F2 for MRA.
                        The controller in combination with DMD2 works beter and is configurable.
                        • Roland Busenhart
                          Roland Busenhart
                          Roland Busenhart
                          Today I navigated 500 km in just under 6 hours from the Kassel area back home—a total of 3 crashes: the first after about 1 hour and 15 minutes, the second after about 2.5 hours, and the last one just before reaching my destination. The app closed on my phone, but after reopening it, I was able to continue navigating. Once again, the track log couldn’t be saved. Sent the log files to support this evening.
                          Using MRA on
                          Ducati Monster 937+
                          Honda X-ADV750
                          • Andries Andries
                            Are you sure?
                            Right now my C1 is set to F2 and is working just perfect.
                            BMW R 1250 GS
                            DMD-NOR7E 7"
                            SPC Universal mount
                            Sena SLR 3
                            Sena 50 R
                              Are you sure?
                              Andries
                              Andries
                              Andries
                              Are you sure?
                              sorry...
                              F1 is for the use with DMD navigation... Think the heat is getting me...
                              Peter Zehentreiter 2 Replies Last reply
                              • Andries Andries
                                Are you sure?
                                sorry...
                                @Andries All right then...
                                I’ve got it...
                                It’s too hot here for motorcycling too.
                                BMW R 1250 GS
                                DMD-NOR7E 7"
                                SPC Universal mount
                                Sena SLR 3
                                Sena 50 R
                                • Andries Andries
                                  Are you sure?
                                  sorry...
                                  @Andries According to the information I have, there should be a function or app on the NOR7E called ‘manage’. This app controls the hardware components.
                                  In the ‘controller’ settings, the cable connection should be disabled; this prevents conflicts between the cable and Bluetooth.
                                  If you opt for the cable connection, you’ll be too tied to the DMD system and limited to certain apps.
                                  BMW R 1250 GS
                                  DMD-NOR7E 7"
                                  SPC Universal mount
                                  Sena SLR 3
                                  Sena 50 R
                                    Andries
                                    Andries
                                    Andries
                                    Yes that is correct for as far i can remember. Thats why i use bluetooth so i can switch between f1 and f2. The dmd2 nav uses f1 and mra uses f2. As long as the temperature outside is below 32°C. I can work with mra.
                                    If you try dmd2 and there upgrade dmd2 next has some interesting features for planning and interface that you can setup like you want. The next is still in progress but looks nice and smooth to navigate.
                                    • Andries Andries
                                      @Andries Thank you for your confirmation.
                                      I received the NOR7E yesterday and have already installed and set everything up.
                                      The Bluetooth connection to the C1 is also set up.
                                      F2 works with MRA
                                      F1 works with DMD 2
                                      I just need to look into the commands for DMD 2 in more detail, as some of the actions are different here compared to MRA
                                      BMW R 1250 GS
                                      DMD-NOR7E 7"
                                      SPC Universal mount
                                      Sena SLR 3
                                      Sena 50 R
                                      • Massimo Cardone
                                        Massimo Cardone
                                        Massimo Cardone
                                        I check the Play Store every day, hoping to see an update for MRA, because on Wednesday morning we’re setting off on the Routes des Grandes Alpes, and if the app keeps crashing – as it has done so far – it won’t be any fun and I’ll be annoyed.
                                        And it won’t just be me who’ll be annoyed, but also my four friends, who all use MRA too. Oh well, we’ll see – as they say, hope dies last.
                                        • Massimo Cardone Massimo Cardone
                                          @Massimo-Cardone Hi Massimo,
                                          Please try to drive completely offline, whilst there’s no guarantee, personally, I’ve had fewer problems – or, to be precise, no problems at all – when driving offline so far.
                                          You’ll need to manually bypass any roadblocks, but apart from that, this setting has caused me the least trouble so far.
                                          Enjoy your trip.
                                          BMW R 1250 GS
                                          DMD-NOR7E 7"
                                          SPC Universal mount
                                          Sena SLR 3
                                          Sena 50 R
                                          • 3
                                          • 4
                                          • 5
                                          Albert van den Elsen
                                          Thomas Neumeyer
                                          Thomas Neumeyer
                                          Léon Hassing
                                          Léon Hassing
                                          Bart 9a 0
                                          Bart 9a 0
                                          Kirsten De Weerd
                                          Kirsten De Weerd
                                          ginogino
                                          ginogino
                                          Kerbel
                                          Kerbel
                                          Massimo Cardone
                                          Massimo Cardone
                                          Peter 3b
                                          Peter 3b
                                          Jozef Malik 0
                                          Jozef Malik 0
                                          Andries
                                          Andries
                                          Roland Busenhart
                                          Roland Busenhart
                                          Myles Lubbock
                                          Myles Lubbock
                                          MarcM
                                          MarcM
                                          Marcel Versluis
                                          Marcel Versluis
                                          • Audio cuttet via Bluetooth
                                            Haug
                                            Haug
                                            35.5k
                                          • One crash today
                                          • Download club route folders
                                          • Elektrisch rijden
                                            John mq
                                            John mq
