  3. Exporting Route To Garmin
4 Posts 2 Posters 504 Views 1 Watching
  • Neil Goodallundefined Offline
    Neil Goodall
    When exporting a GPX 1.1 route to my Garmin using the 'Export' button the results on the device are odd. Upon opening the route in the application/Trips option and navigating from there the route is shown in 'straight lines' NOT on the roads. However, if you return to the list of instructions and tap on the blue dot (shaping point I think) the Garmin recalculates the route and then when looking on the map the route follows the roads. If I export as a GPX 1.0 file my route is split into 2 (I suppose it's a GPX 1.0 limitation) but it does store the route as all waypoints (orange flags)
    Reinhard-32undefined 1 Reply Last reply
    • Neil Goodallundefined Neil Goodall
      Reinhard-32undefined Offline
      Reinhard-32
      @Neil-Goodall You didn’t mention which device you’re using. If it is a ZumoXT than the GPX 1.1 (beta) is usefull. In other cases you can use th GPX 1.1 format. After importing the route into the Device it endet up with straight lines. Then click to the car symbol and change the profile. The route will calculated. After that click the symbol angain and switch back to the original profile. A recalculation starts again and the route will follow the streets..
      Kindly regards
      Reinhard
        Neil Goodall
        Thanks for the suggestion Reinhard but this is a Garmin and the car symbol doesn't do anything when tapped.
          Reinhard-32
          @Neil-Goodall Ok, I have a ZumoXT and my suggestion was based on it.
          But can you tab at the first waypoint symbol without alarm and change it to alarm visa versa ? That initiates a new calculation at my ZumoXT and maybe at your device as well.
          Kindly regards
          Reinhard
          Reinhard-32
          Neil Goodall
          • Ignore road closures.
            Herman Veldhuizenundefined
          • Camper
          • Autovelox
            ginoginoundefined
            ginogino
          • New beta! 5.0.2 (438) - free drive
            b0hd1undefined
          • Bij Track loggen mis ik de kaart laag openstreet
          • Zwart menu in de app!
          • Route navigeert niet
          • MRA V5.0.1-438 Camper + MRA App Routenplaner
