  4. Log in
Log in
13 Posts 5 Posters 38 Views 3 Watching
  • Rod Sydenham
    Rod Sydenham
    Rod Sydenham
    When logging in, is it possible to save the login credentials? Old guy with fat fingers here. Having to enter in username and password each and every time, when logging into the app on the phone, is cumbersome.
      Just do not log out! but just stop the app
      • Reinhard Punz
        Reinhard Punz
        Reinhard Punz
        I use the Google Chrome browser, which offers the option to save usernames and passwords. This saves you from having to type them in.
        Rod Sydenham 1 Reply Last reply
          The app remembers your login: once you're signed in, you stay signed in, even after closing the app or restarting your phone. You only have to log in again if you tap "Log out" yourself, so the tip above is the right one: just close the app instead of logging out. You also don't have to type it yourself: the login fields work with your phone's password manager (iCloud Keychain on iPhone, Google Password Manager on Android). If your login is saved there, tap the email field and pick it from the suggestion above the keyboard.
          • Rod Sydenham
            Rod Sydenham
            Rod Sydenham
            That would be great if I didn't have to actually log out of one phone in order for the other one to work. (see my post in the problems area). If I have both phones open and logged in, I have to completely log out of one in order for the other to access things like my library with the remaining one. If only one phone is logged in (doesn't matter which one) things work as they should. It seems that my account is only recognizing one device at a time even though there is 2 registered.
            I get either "no internet connection" or "scouldn't refresh" messages. Doesn't seem to be any set of circumstances that dictate one or the other.
            • Reinhard Punz Reinhard Punz
              Rod Sydenham
              Rod Sydenham
              Rod Sydenham
              I am referring to logging into the app on my Android phone.
              Login is not an issue on my desktop.
                Well the only solution in that case is to use a password manager on the phone.
                I’ve had a good experience with LastPass myself, both on my computer and on my phone and tablet! And it's for free. Then you have only to remember one password for all and if your phone support fingerprints even that is not necessary anymore.
                And yes, I'm also an old guy with fat fingers.
                • Parantapa
                  Parantapa
                  Parantapa
                  If you tap on your profile in the top right-hand corner of the app, you’ll find the ‘My devices’ option under ‘This phone’. How many devices are listed there? You might want to try removing all devices except the one you’re currently using to view this. Then log in to the other device again and see if it works now.
                  • Rod Sydenham
                    Rod Sydenham
                    Rod Sydenham
                    I uninstalled and reinstalled the app on both phones. No joy. The issue seems to be the beta site not recognizing more than one device even though there are 2 listed. Note:
                    One is showing as "removed" Nov 6 even though there is no provision for removing a device so I cannot "remove" a device.
                    Both devices can be logged into, and function fine, on the original app. This seems to be a "beta" issue.
                    • Parantapa
                      Parantapa
                      Parantapa
                      Yes, that's the same device twice. That's strange. It's not Beta's fault; I have two devices listed there.
                      • Rod Sydenham
                        Rod Sydenham
                        Rod Sydenham
                        Both devices are Motorola stylus 5G phones. Build numbers are the same but all other identifiers (eg. IP address) is different. Since both phones work on the "legacy" app and this is the screen shot of the device page in that app
                        (identical to the screen of the "beta} version), I can't help but think that there is a glitch in the 'beta" app with regards to my account.
                        • Parantapa
                          Parantapa
                          Parantapa
                          Yes, you might want to open a support ticket.
                          • Rod Sydenham
                            Rod Sydenham
                            Rod Sydenham
                            I just submitted a ticket.
                            Parantapa
                            Parantapa
                            Rod Sydenham
                            Rod Sydenham
                            Reinhard Punz
                            Reinhard Punz
                            • Log in
                              Rod Sydenham
                              Rod Sydenham
                            • Restriction on scenic length?
                              Jeroen ekkel c
                              Jeroen ekkel c
                              Andy Beviere
                              Andy Beviere
                              1.7k
                            • AI pricing is too high
                              Cleo
                              Cleo
                            • Nieuw start punt maar krijg de route niet hernummerd in logische volgorde
                              Juudje39
                              Juudje39
                            • Library Structure
                            • Allow the last entered point to be set as a via point
