  4. Why does route change when connecting to Android Auto?
13 Posts 8 Posters 398 Views 4 Watching
  • Brian Martinundefined Offline
    Brian Martin
    Quite often after selecting a route on my Android phone then connecting to Android Auto the route changes. After carefully designing a route on my pc and syncing it to my phone and after connecting to Android Auto and Start navigation, I find part of the route sometimes gets changed. It's most frustrating as I have to keep checking the map before I start navigation to make sure my original route hasn't been altered. Anyone else have this happen?
    • Brian Martinundefined Brian Martin
      Rob Verhoeffundefined Offline
      @Brian-Martin In principle, Android Auto is a mirror of your phone, and AA will not change a route on its own. Any route changes would also occur on your phone as soon as you tap Navigate.
      Could it be that you created the route using a different map than the HERE map (for example, OSM or TomTom)? Are any road closures visible on the map along the route you created? Which area does the route pass through? Is there a seasonal road closure involved?
      It might be helpful to share your route in this topic so others can take a look.
      Atse Kroesundefined 1 Reply Last reply
        M. Schrijverundefined Offline
        Not especially altered. But when connecting to Android Auto after starting a route on the smartphone. MRA seems to do a sort of refresh. This does things with the route. You see things happens on your phone screen.
          That can only be the case when selecting a A B route. A route from your librairy doesn't change
          • nomkoundefined Offline
            @m.-schrijver
            Did you placed enough waypoints? And what are the settings in your MRA app?
            And as @rob-verhoeff said, please share the route and provide more info.
            | MRA Gold Member |
            | MRA Next + Kawasaki Z650 |
              waypoints are not the issue. In my case the routes are not altered but when connecting to Android Auto i see things happening on the screen of the phone. It looks like MRA is bit confused whats going on.
              • Herman Veldhuizenundefined Online
                Could it be that there is a closed road on your route? Then the route could indeed be different than what you see in the planner and it is indeed very frustrating when you have used the HERE maps only and when timing is not the issue (navigating straight after editing).
                  Atse Kroesundefined Offline
                  Atse Kroes
                  @Rob-VIkerhoeff
                  Ik heb hetzelfde probleem. Ik lees elders dat je beter Here map kunt gebruiken. Ik heb TOTOM map gebruikt. Is het waar dat ik dus beter Here map moet gebruiken voor in de auto met MRA app te reizen?
                  Groet Atse Kroes
                  • white.mouseundefined Online
                    wrote last edited by white.mouse
                    Ja. De navigatie werkt altijd met de Here map. Dus als je een route maakt met een andere kaart als laatste de route op de Here-kaart leggen en controleren.
                    Yes. The navigation system always uses the Here map. So if you plan a route using a different map, make sure to finalize the route on the Here map and check it.
                      Brian Martin
                      Thanks for the replies. I do use the here maps and I use MRA in offline mode. I shall keep monitoring the situation to see if it keeps happening. I have an existing route planned for tomorrow, so I'll see if it behaves itself or not.
                      • Atse Kroesundefined Offline
                        Atse Kroes
                        Als ik de knop start indruk van de route dan verschijnt er een popup schermpje met de tekst; 'TomTom route Track navigatie gebruiken'
                        Wat betekend dit???
                          wrote last edited by Herman Veldhuizen
                          Using here maps only is no guarantee that the navigation comes with the same route as what you crafted in the planner. At least that is what I have observed. Dont know where the problem is. Could it be that planner and navigation are not using the same user settings? Differences between the routing engine in the app and on the server?
                            @Herman-Veldhuizen Or maybe you should use more route points at critical locations! I use as few as possible, but as many as necessary... šŸ˜‰
                            Atse Kroesundefined
                            Atse Kroes
                            Brian Martin
                              Rae Sewellundefined
                              Rae Sewell
                              1.1k
                            • OU peut on changer les couleurs de la route
                              LE DIZES Freddyundefined
                              LE DIZES Freddy
                            • Why does route change when connecting to Android Auto?
                            • Offline navigation as of June, 2026 release 5.1
                              Mzokkundefined
                            • MRA connector - Zumo XT (+SD)
                              Guztundefined
                              Guzt
                            • Symbolen
                              Hans Kragtundefined
                              Hans Kragt
                            • MRA does not recognize RemoTek One remote commands:
                              Doug Crockerundefined
                              Doug Crocker
