  3. MRA and Color
MRA and Color
5 Posts 3 Posters 1.3k Views 3 Watching
  • RideOnWithFriends Offline
    RideOnWithFriends
    Can I change the route color in the myRoute app? I have different route segments and would like to, for example, display the on-road part in blue and the off-road part in red. Is this possible, and if so, how? Otherwise, I'll have to edit the route in other tools that support this. Thank you for your help.
    Best Regards - cu on my channel
    https://www.youtube.com/@rideonwithfriends
    Juergen
    • RideOnWithFriends RideOnWithFriends
      Rob Verhoeff Offline
      @RideOnWithFriends
      Unfortunately, that’s not possible — especially not while navigating in the mobile app.
      You can display an overview of your complete route using different colors, though. To do that, you need to save the off-road sections as separate routes and then merge them with the other sections. But that's in the website planner only! You can find instructions on how to do this in the help files of the Routeplanner.
      RideOnWithFriends 1 Reply Last reply
        @RideOnWithFriends
        RideOnWithFriends
        @Rob-Verhoeff
        Thank you very much!!!
        Unfortunately, this is very cumbersome and time-consuming.
        Juergen
        • Hubert Thoring Offline
          @RideOnWithFriends ;
          Hallo Juergen, nein umständlich ist das nicht. Im normal Fall hat man sowieso die Routen in einem Ordner abgelegt. Öffne diesen Ordner dazu der erste Route und dann kann man mit zwei klicks die Rouren alle sichtbar machen und sorag die Farben auswählen, so zeige ich meien Freunden immer alle Routen auf einen Blick. WP1 und WP2 ist die Route vom Hotel zur Tankstelle, die öffne ich und zeige dann alle anderen Routen auf diesem Weg ganz schnell und einfach, farben lassen sich dort ändern.
          VG
          Hi Juergen, no, it's not complicated at all. Normally, you'd have all your routes saved in a folder anyway. Open that folder, select the first route, and then with two clicks you can make all the routes visible and even choose their colors. That's how I always show my friends all the routes at a glance. WP1 and WP2 are the route from the hotel to the gas station; I'll open them and then quickly and easily show all the other routes along this path; the colors can be changed there.
          Cheers!
            Mittlerweile geht das auch sehr gut in der App …
            RideOnWithFriends
            RideOnWithFriends
            • Welke instelling
            • Bug: snelweg vermijden opheffen na wegvallen verbinding? + vraagje gpx file
            • Planned routes not available during lack of Internet connection
            • nieuwe Belgische gebruiker
