  3. [App] Announcements
  4. New update! (4.4.0)
New update! (4.4.0)
19 Posts 14 Posters 2.3k Views 5 Watching
    Hi everyone! 👋
    Coming week update 4.4.0 will be released to the public!
    This update might not have the most spectacular changes but I'm sure you will be happy with it! Why? After a very long time of working together with HERE we identified why some users still experience a massive amount of battery usage. This update is the first in which that is reduced! 🎉
    The first? Yes! More updates to come for sure regarding issue now that we know where to look. After testing on a lot of different devices we see a relative improvement of ~20%. Note: not all devices had this issue and not all devices will experience the same improvement.
    That said, I am confident everyone will have a smoother app experience and less strain on the CPU / GPU leading to better battery life and charging capabilities.
    What else is new in this update:
    • The route "eat-up" is now seamless meaning that the route line won't have a weird animation anymore where the progress (part you drove) was ahead or far behind your current position
    • Fixed an issue where the start page map position would not show your heading correctly
    • Fixed issue where tap to recalculate would not trigger
    • Support new SilverFox firmware (soon to be released by them, solving issue where long press a button also resulted in short press being triggered)
    • Improved contrast in menu's when navigating them with a bluetooth controller
    • Minor improvements to waypoint skip algorithm
    • Internal updates
    Curious to learn your experiences regarding the battery usage! Do know that more improvements will be coming 🙂
    Cheers,
    Corjan
    Gos Kuusundefined 1 Reply Last reply
    • Cookie On Tourundefined Offline
      Cookie On Tour
      Thank you!
      Joerg
      (Cookie-On-Tour.de)
        Hi everyone! 👋
        • Internal updates
        Cheers,
        Corjan
        Gos Kuusundefined Offline
        Gos Kuus
        @Corjan-Meijerink Today I drove a by MRA generated Roundtrip. Driving 3:15 hours and 115 km. Tour went well. Just one "turn left" had to be "turn right" because after 100 meters I had to make an U-turn. Not dramatic. Recalculation was quick and sufficient when I deliberately left the tour.
        "Eat-up" of the route line was OK.
        Battery usage is indeed improved. Iphone became, let's say, warmer as handwarm. Display was turned of and phonecover was open. Environment temperature was approx. 24 degrees Celsius in a cabrio with open roof (of course). Sky was cloudy/sunshine. So, not to much direct sunshine on the phone. Loading process wasn't stopped because of temperature.
        Very eager to learn next update in this. 👍
        Test was done on Carplay with an Iphone 13, MRA 4.4.0 - 404
        • Mzokkundefined Offline
          wrote on last edited by Mzokk
          Looking forward to trying it. I had 4 days / 900 miles 1500 km round Scotland last week using Android Auto on my Honda Africa Twin Adventure sports via a Motorola Edge 40 Neo and the (last iteration) of the app was faultless including routes designed with optional loops (no via points only shaping) two of which I skipped and the app continued perfectly after the next waypoint was encountered. I still have a Garmin XT mounted on the bike but its only used for custom proximity shown POI's and I run a confirmation track of the MRA route I'm running. Many thanks. Oh and it was 27C on Mull last Friday. Most unusual!!
          • C.A. Kielenundefined Offline
            C.A. Kielen
            I use the app every day during my current 4-month trip. Last month in Iraq, I put the phone in the driving wind to cool it down. As soon as I arrived in a city with the usual congested traffic, the phone overheated and started giving a less and less clear picture until it stopped completely. Just when you need it the most. So I am very happy that the problem is found and my phone no longer overheats. To prevent overheating it also helps a little if you stop charging the battery.
            C.A. Kielenundefined 1 Reply Last reply
            • Hns_Brwrundefined Offline
              Hns_Brwr
              ik ga morgen gelijk testen, 360km dus dat hoop ik te voltooien met mra
              • CD130undefined Offline
                Vandaag uitvoerig getest. Mooi op te zien dat de blauwe lijn nu gelijk loopt. Had wel meerdere keren dat de app vastliep rondom stops. Ik maakte gebruik van CarPlay.
                  M. Schrijverundefined Offline
                  The battery usage is certainly improved. The phone was cooler today and less trouble to keep the battery charged. Good job.
                    There is an Autozoom in Android Auto. I can clearly see this on my screen. But how it works? I don't know. It looks random.
                    My setting is "Both" (speed and directions/crossings). Biggest complain. The crossing with a white arrow shows up in the screen only 120-140 meters before you arrive at the crossing. Too late.
                    The blue line and position indicator are looking good. Did not see any strange things. Smooth graphics. Good job.
                    There is still a clear delay in real position and position on screen. Combine this with the issue of the Auto zoom and you can understand there is an issue.
                    What i noticed about the delay in the position indicator compared to other navigation apps.
                    Other navigation apps are more on par with the real position. But when you take a wrong turn it takes those other apps a longer time before they noticed you took a wrong turn.
                    It seems all navigation apps have the same issues but those other apps do a more aggresive correction to keep it the indicator better on par with your real position.
                    • C.A. Kielenundefined C.A. Kielen
                      C.A. Kielen
                      Drove all day today. After 2 hours of driving 35% battery used. That is real progress. Phone stayed cool all day.
                      • Luk4s7undefined Offline
                        Luk4s7
                        I posted my last weekend issues with app here https://forum.myrouteapp.com/post/67675
                        In short: still "eats-up" the route and crashes (after eating enough) 😉 Some arrow drifting not able to show correct position (while Google Maps and Apple Maps all work fine).
                        I'm a bit frustrated as during motorcycle ride reliability is a key. Stopping and restarting navigation app it annoying. Hope you understand.
                        • Jan 50undefined Offline
                          Jan 50
                          wrote on last edited by Jan 50
                          On a Samsung SE21FE battery is not impoved. Phone stil gets very hot...
                          Also the app stil crashes (see ticket).
                            A hot/warm phone is fairly normal when navigating. It differs per app but all phones are getting warm/hot when navigating.
                            But yes. MRA still uses on average still a bit more power compared to other apps. But it is a lot better than a few years ago.
                            • henry van den beltundefined Offline
                              henry van den belt
                              Helaas, navigeren met mijn telefoon zorgt nog steeds voor een hoog batterijverbruik. Nieuwe accu, nieuwe laadpoort, nieuwe usb laadaansluiting, nieuwe laadkabel.
                              Voorlopig gebruik ik MRA niet meer om te navigeren tot het probleem is opgelost. Ik heb lifetime abbonement dus dat zal ooit wel gebeuren, toch?
                              Voorlopig is Kurviger aan zet.
                              Kreeg tijdens mijn vakantie in Kroatië een lekke band met de motor. Toen ik ff wilde bellen dat ik met een probleem stond en het wat later werd bleek ik nog 16% accu te hebben op m'n telefoon. Dan wordt ik toch een beetje zenuwachtig
                              • D Griffinundefined Offline
                                D Griffin
                                How do I tell what version I have? Will it automatically update me? or will I at least see a prompt?
                                • D Griffinundefined D Griffin
                                  @D-Griffin Open your account on your smartphone, scroll all the way down, and you'll see which version is currently installed.
                                  Currently, 4.4.0-404 is the latest version Android and iOS
                                  Updates will be installed automatically, provided you've allowed automatic app updates in the Play Store / App store
                                  BMW R 1250 GS
                                  BMW Connected Ride Cradle
                                  SPC Universal mount
                                  Motorola Edge 40
                                  Sena SLR 3
                                  Sena 50 R
                                  • henry van den beltundefined henry van den belt
                                    @henry-van-den-belt said in New update! (4.4.0):
                                    Dingen nieuw kopen is alleen een oplossing als je de juiste dingen koopt.
                                    Gebruik je de MRA app met Carplay of Android Auto toevallig? Ik heb de indruk dat AA/CP connecties méér stroom verbruiken dan de MRA app zelf.
                                    Een powerbank in je tanktas werkt goed tegen zenuwachtigheid 😉
                                    henry van den beltundefined 1 Reply Last reply
                                      henry van den belt
                                      Yep., de accu van de telefoon was al wat ouder dus vandaar laten vervangen.
                                      Niet perse omdat ik dacht dat daar het probleem in zat. En inderdaad had ik ook nog een powerbank bij.
                                      Maar wat ik eigenlijk wilde zeggen is dat de app nog steeds behoorlijk veel verbruikt
                                      Jan 50undefined 1 Reply Last reply
                                        Jan 50
                                        wrote last edited by Jan 50
                                        @henry-van-den-belt ik heb ook deze ervaring met een Galaxy S21FE. Telefoon wordt ook erg warm wat denk ik vooral invloed heeft op de stabiliteit. Op vakantie, in de auto, de telefoon in de airco luchtstroom gehouden waarna de app wel redelijk stabiel was.
                                        Heb in het ticket #55262 weer input gegeven. Zou fijn zijn als daar ook naar gekeken wordt (en een keer op wordt gereageerd).
                                        Mzokkundefined
                                        CD130undefined
                                        Hns_Brwrundefined
                                        Hns_Brwr
                                        D Griffinundefined
                                        D Griffin
                                        Cookie On Tour
                                        Jan 50undefined
                                        Jan 50
                                        Gos Kuusundefined
                                        Gos Kuus
                                        henry van den belt
                                        Luk4s7undefined
                                        Luk4s7
                                        C.A. Kielen
                                          Lex.Kloet.RXundefined
                                          Lex.Kloet.RX
                                        • How to do this
                                          BertMundefined
                                        • Routepunten
                                          Corrado Miniati 0undefined
                                          Corrado Miniati 0
                                          1.3k
                                        • impossibile tracciare itinerari a piedi o in bicicletta
                                        • route wil niet over zandwegen die wel gewoon toegankelijk zijn
                                          Wim Peetersundefined
                                          Wim Peeters
                                        • "Show next waypoint information" - another hidden UI filter!
