  3. [Web] Announcements
  4. Scenic routing & RouteXpert library improvements
32 Posts 18 Posters 26.8k Views 8 Watching
  • MarcM
    MarcM
    MarcM
    wrote on last edited by MarcM
    @Corjan-Meijerink Nice nice nice, Question: When I make route from A to B (in the Alps) and when I click on "Routes Nearby", I have to open route by route, it would be very nice if I can see the same as when I open the Bib ...
    • Bart De Medts
      Nice Job @Corjan-Meijerink
      • Albert van den Elsen
        Thank you Corjan and your team. Nice work
        iPhone 15,
        Garmin Zumo XT3
        Carpuride W702 Pro
        Sena 20S EVO headset
        Harley Davidson Road King M8
        • James Lewington
          James Lewington
          James Lewington
          Great work, looking forward to using this on my next ride!
            Just saw the update in the planner and wondered how about! But the explenation is good! And Fortunately, the two options have different colours.
            Good job done!
            • Edwin_M
              Edwin_M
              Edwin_M
              Nice, but I ran into an issue, unable to create a roundtour in curvy and very curvy
              • Edwin_M Edwin_M
                @Edwin_M please try again 🙂 Throughout the day we kept making some changes.
                Edwin_M 1 Reply Last reply
                  Edwin_M
                  Edwin_M
                  Edwin_M
                  @Corjan-Meijerink just now (in house at front near road) finish at the back (brandgang) wasn't able to get a route at the garden, so tried to.move to the front to see if that would change something.. But later I saw that finish stays at the back
                  • Tony 13
                    Tony 13
                    Tony 13
                    Already tweaked a couple of routes. Very useful
                    • Ralph c
                      Ralph c
                      Ralph c
                      Just saw the overlay, and a very big improvement. Like to create my own routes and this helps a lot picking the right roads.
                      Awesome job guys!
                      • Edwin_M
                        Edwin_M
                        Edwin_M
                        Bij mij werkt het nog niet echt lekker.
                        Even een route maken in de tuin zorgt alleen maar voor fouten. Ook via de website (op telefoon). Vind het ook best traag
                        Ook een willekeurig ander adres
                        • Edwin_M
                          Edwin_M
                          Edwin_M
                          Update!! Het werkt nu.
                          Zojuist de nieuwe Beta en nu werkt het prima
                            Fantastisch. Eerst kwam de GPS shop uit Notter met de motorkaart voor de Garmin, speciaal voor motorrijders. En nu komen jullie met iets soortgelijks. Echt vergelijkbaar. Dit maakt alles nog weer mooier!
                            Fantastic. First came the GPS shop from Notter with the motorcycle map for the Garmin, especially for motorcyclists. And now you come up with something similar. Really similar. This makes everything even more beautiful!
                            • Edwin_M
                              Edwin_M
                              Edwin_M
                              Te vroeg gejuichd, stap op motor. Klik rondrit. Weer zelfde meldingen. Geforceerd afsluiten en opnieuw, geen verschil
                              • Edwin_M
                                Edwin_M
                                Edwin_M
                                #24
                                When I finally got it going.. It came up with route 4 times longer then requested
                                • Edwin_M Edwin_M
                                  @Edwin_M said in Scenic routing & RouteXpert library improvements:
                                  Daar moeten de dev's zeker nog wat tweaken. Ze hebben deze al in het vizier.
                                  That definitely still needs to be — and is being — tweaked by the devs!
                                  • stuart marritt
                                    stuart marritt
                                    stuart marritt
                                    Trying to do a scenic route from my home to a location all I get is this?
                                    • AWDC LAO
                                      BRAVO !
                                      • Edwin_M
                                        Edwin_M
                                        Edwin_M
                                        I did a few tests just now. Works a lot better. Distance ok and speed of generation was much faster
                                          Indeed fixed the big OSM issue. Unfortunately the new higher quality route generation has been undone for now. Back up soon again! But the big fire has been extinguished 🙂
                                          Edwin_M
                                          Edwin_M
                                          Tony 13
                                          Tony 13
                                          iain.gardengmail.com
                                          stuart marritt
                                          stuart marritt
                                          MarcM
                                          MarcM
                                          Ralph c
                                          Ralph c
                                          James Lewington
                                          James Lewington
                                            TomOnTour
                                            TomOnTour
                                          • Pay for beta?
                                          • Live payments enabled
                                          • Maps Michelin
                                            LE DIZES Freddy
                                            LE DIZES Freddy
                                            1.1k
                                            Brett Bartick
                                            Brett Bartick
                                            TomOnTour
                                            TomOnTour
                                          • import in beta-mra failed
