  4. Viewing mode Top Down / North / Dynamic
6 Posts 4 Posters 70 Views 2 Watching
  • Jörgenundefined Offline
    Since I've had the remote control, I often use the zoom buttons to look something up and then quickly want to go back to the dynamic view.
    After zooming, the view is in top-down mode, and you have to press the compass or ‘C’ twice on the remote control. (The sequence is Top Down / North / Dynamic)
    I don't know if it's just me, but I would like to have the dynamic view after zooming, after the first tap.
    (The new order would be Top Down / Dynamic / North)
    Who actually set the order for the view, or is there a specific reason for it?
    • Jörgenundefined Jörgen
      @Jörgen I guess it's the same thing as with my Silverfox H1 whenever you use one of the buttons the view changes and you have to scroll through the camera views
        Hmm, in the AA/CP mode I think the view actually does return to the last one used when you exit the zoom menu. In the app natively it appears not indeed. On the other hand, if you wait it out for 5 seconds or so, it actually does go back to the previous mode. But I can see your wish.
        • Stanisławundefined Offline
          Maybe would be possible to put the North-up view to the settings? I suppose only a few users need it. During the ride I always want to see upcoming road ahead.
          Staszek
            @Con-Hennekens the remote sends 2 codes
            1 short push
            2 long push
            In case of the long push it will also send the code for the short push. That's was causes the problem
              1 short push
              2 long push
              @Marinus-van-Deudekom, Ah, okay, did not know that. Thanks for the insight.
              Stanisławundefined
                3.0k
              • Crashes na update
                Jan Weerheimundefined
                Jan Weerheim
              • Doe ik iets verkeerd of...
              • Duizend bochten
                Herman Veldhuizenundefined
