  4. Carplay on IOS - Remote controllers?
7 Posts 4 Posters 2.4k Views 4 Watching
  • ianlwelshoutlook.comundefined Offline
    Hello. I use MRA on IOS and use a Carpuride for Carplay.
    Do any of the Bluetooth remote controllers work to control the Carplay screen (eg Zoom, Skip)?
    Thanks
    Adrian Avramundefined Hubert Thoringundefined 2 Replies Last reply
    • ianlwelshoutlook.comundefined ianlwelshoutlook.com
      Thanks
      Adrian Avramundefined Offline
      @ianlwelshoutlook-com you should have bought Chigee with their remote control. Works great !
      Adrian
        @Adrian-Avram I think you are right! Ah well.
          Thanks
          @ianlwelshoutlook.com
          Look here in the car tested with an iPhone Xr of the MRA and the Remotek One ...
          Zoom and skip WP.
          Video im Auto
            One very important remark.
            Any bluetooth controller paired with your phone aimed to control our app will not work when the MRA app is in the background / another app is open / the phone is locked.
            Controllers such as Chigee offer, do not control MRA but they control the CarPlay / Android Auto environment which is a whole different thing by itself.
            Do not buy a Remotek / SilverFox / etc.. if you intend to use CarPlay / Android Auto with your phone put away 😉
              That's was it meant, with the Remotek One you can only control an Active MRA app, this then has an indirect effect on the display of the CarPlay appearance. It is only an indirect solution to the motorcycle, but a possibility that exists.
              VG 👋
              So war es gemeint, mit der Remotek One kann man nur eine Aktive MRA App steuern, dieses wirkt sich dann indirekte auf das Display des CarPlay Erscheinungsbild aus. Es ist nur eine indirekte Lösung am Motorrad, aber eine Möglichkeit die es gibt.
              VG 👋
                You have to get a controller compatible with your carplay device. So Chigee has dedicated remote that connects via bluetooth to the device.
                As far as I know there is no bluetooth remote control compatible with Carpuride.
                Adrian
                  richard 3vundefined
                  richard 3v
                • Crashes na update
                  Jan Weerheimundefined
                  Jan Weerheim
                  Reinhard Punzundefined
                  Reinhard Punz
                  3.1k
                • Duizend bochten
