  3. Circle POI beta.gpx
Circle POI beta.gpx
9 Posts 3 Posters 1.8k Views 2 Watching
  • Aiello antoninoundefined Online
    ![alt text](image url)if you save a route as BETA gpx, with also POIs, you import on basecamp, around the POIs there is a circle, what does it mean? I'm new to the garmin world ...!!DEFA1352-E09C-4B47-ABD4-CCBFAE7E9401.jpeg
      Jack van Tilburg
      This is a specific question about Garmin and Basecamp.
      You can get a warning when you get close to a POI while navigating.
      The circle in Basecamp indicates where the warning is given.
      In Basecamp you can specify this radius in the tab <advanced> in the properties of the relevant POI.
      Aiello antoninoundefined 1 Reply Last reply
        @Jack-van-Tilburg
        but this "circle" I find it when I import the beta gpx file in basecamp without modifying or touching anything in basecamp
        • Aiello antoninoundefined Aiello antonino
          @Jack-van-Tilburg
          Jack van Tilburg
          @Aiello-antonino
          The POI's have a radius of 100 meters by default in MRA. But you cannot adjust that in MRA.
            Hans van de Ven MR.MRAundefined Away
            @Aiello-antonino
            If you use a colored routepoint in MRA, then the circle is added, it has no use at this moment
              @Aiello-antonino
              @Hans-van-de-Ven-MRA-Master
              Then there will be no warning in basecamp !? will it be useful in the future?
                @Aiello-antonino
                Maybe....
                  @Aiello-antonino
                  Maybe....
                  @Hans-van-de-Ven-MRA-Master quale è il metodo migliore per fare in modo che il “percorso” fatto su MRA sia perfettamente uguale sullo zumo?
                    @Aiello-antonino
                    By correctly placing the route points on the Here map route line
                    Jack van Tilburg
                      AWDC LAOundefined
                    • Waypoints and POIs disappear while moving/zooming the map in web planner
                      Tom Balmerundefined
                      Tom Balmer
                    • Track log functionality - compared with BaseCamp
                      John Matthews 0undefined
                      John Matthews 0
                    • Veerpont als routeovertreding gaat te ver
                    • Wegwerkzaamheden
                    • Fout in route bibliotheek
                    • Testrit met AA ivm tracklog
                      supergundefined
