  3. loop route
loop route
3 Posts 2 Posters 775 Views 2 Watching
  • dennis 4m Offline
    dennis 4m Offline
    dennis 4m
    when setting up a loop route, my Garmin Zumo XT2 wants to immediately route me to the starting point. Is there a particular way that is required to make the loop route work.?
    Thanks, sorry if this is route planning 101, but I didn't realize this was happening until starting this trip.
    Any help appreciated....
    • Mzokk Offline
      Mzokk Offline
      When planning a loop route for use on a Garmin XT XT2 make sure that
      1. you have your start point a few hundred meters away from where you are this ensures that the unit passes through the start and does not try and take you back through it if you miss it by a bit for example if you start a route at your hotel start it up the road a bit in your intended direction of travel as a slight mistake in the position of the start in a hotel car park might mean you miss the actual start.
      2. If making a loop route make sure that there is at least one via point at the farthest extent of the loop (On a Garmin these show up as flagged waypoints a hand in MRA) rather than just standard waypoints (a drop point in MRA and a blue dot in Garmin called a shaping point). This means that if you miss a waypoint and the unit recalculates it won't take you directly to the finish(Which is always a Via point.)
      3. I have an XT and tend to download the route file in the form of a GPX1.1 route and track. I have both visible on the screen when navigating in a contrasting colour so that I can see if the Garmin has recalculated the route and made it different (the track stays as shown on the MRA screen)
      4. I tend to leave recalculation as prompted on Garmin units and navigate myself back to the route though I do sometimes allow recalculation.
      • dennis 4m Offline
        dennis 4m Offline
        dennis 4m
        Thanks MZOKK,
        I'll give that a try, I made the changes in some of the upcoming loop routes,
        Much appreciated,,,
        dennis 4m
        dennis 4m
          1.4k
        • die selbe Route/Strecke zurückfahren, wie vorgehen bei Generierung der Navi Daten
        • Hiding home address / waypoint for shared routes
        • Points of interest
          1.8k
