  4. Battery drain
Battery drain
36 Posts 11 Posters 397 Views 3 Watching
  • Mario Ivancic
    Mario Ivancic
    Mario Ivancic
    My experience is that using dark mode and slightly dimming the screen solves the battery drainage issue. It's an illusion to think that you can drive for hours with any navigation without needing some charger. That's just not realistic, and such technology hasn’t been invented yet. The problem, as I see it, is actually quite simple. HERE has decided to use a lot of white in their display, which particularly burdens phones with large, bright screens. Other apps are not so "white" and consume less energy to illuminate the screen. I would say that some designer is to blame here, rather than the developers themselves. The developers probably did as they were instructed. And now it turns out that some low-resolution, dimly lit, small-screened “shitphone” performs better than top-of-the-line phones. Maybe I'm wrong, because it surprises me that nobody else has noticed this "whiteness". If I'm on the right track, and the folks at HERE haven’t noticed this design flaw... well, it won’t cost them much, I’ll drink a beer on their tab. 😉
    • Mario Ivancic Mario Ivancic
      @Mario-Ivancic, your colorful opinion does not explain why for example the equally white Google Maps app does not suffer from the drain... 😉 It has already been established that the rendering engine is the SDK is to blame. Whether a dark theme helps or not is dependant on the type of screen you have in your phone.
      Also the issue is not about draining the battery in hours, but draining the battery in hours DESPITE being charged simultaneously.
      Mario Ivancic 1 Reply Last reply
        Mario Ivancic
        Mario Ivancic
        Mario Ivancic
        Well, at least to me, Google Maps seems darker. This is probably due to my professional bias since I work with printers and printer applications. Without actually testing the darkness level of both examples (yes i have tools for that), I would say, just by looking, that Google Maps is darker and would use more toner if printed in the same format. (Toner's like cash, so the darker sometnihg is, the more it itches me. 😉 )
        In any case, using a darker background will undoubtedly result in energy savings. Just like dark mode solves the problem for me.
        Clearly, optimizing the code itself can't hurt. But changing to darker colors is a relatively simple solution. And can make some savings on energy that screen uses, for sure.
          @Mario-Ivancic said in Battery drain:
          I am not denying that, it is just no solution for the battery drain due to a bug in the rendering engine. I'd say it is small beer compared to that 😉
          Drabslab 1 Reply Last reply
            Yes, i know.
            But i've noticed something.
            When you follow the route exactly as planned in advance. And because of this no recalculation are needed. The battery usage is almost on par with other apps like Google maps, Waze or TomTom Go.
            But when you have a bad route which needs multiple recalculations especially within in few kilometers. The juice is sucked out of the battery very quickly.
            The other day i went from 90 to 80% in two hours. I had 2 recalculations in this time. Then i went from 80 to 50% in 30 min. In this period i had multiple recalculations in a small area (roads closed, wrong roads, etc).
            The last part was 1 hour with one recalculation and went from 50 to 44%
            My first route this year was a very well known route (for me). The route was therefore exact. It is a 4 hour ride. No recalculations needed. I went from 100% to 95% in 4 hours. Still a bit high consumption but no problem for a riding a whole day.
            @M-Schrijver this definitely does not affect my phone...it is a pig on drain on the most meticulously planned route (no alterations, no recalcs, followed to a 'T') as it is with a simple A-B route planned last minute with mulitple detours. And now that the ambietn temp outside (Texas) is getting very spring/summer like, it is even worse - screen becomes so dim (yes, brightness, etc, all the way up), it is virtually illegible to see, making using the app a waste of time. Very frustrating.
              @Con-Hennekens said in Battery drain:
              even a small beer is still a a beer 🙂
              Point remains that this should be solved urgently as it affects many users, and leads to negative publicity for the tool.
              • Drabslab Drabslab
                @Drabslab, Yes, I think we agree on that!
                • Andrew
                  Andrew
                  Andrew
                  Went out on my bike yesterday with AA Carplay for a 240 ml run when I came back the phone still had a 99% charge well pleased with that, hope this continues. And the app know has not dropped out for the last 3 times I have used it.👍 👍
                  • Simon Ferrari
                    Simon Ferrari
                    Simon Ferrari
                    Not sure if it's related but I can't follow a route for more than about 2 hours before my iphone overheats and won't display anything in the car. I'm using wired car play so the phone is charging at the same time so I don't have battery drain but I suspect the app is causing pushing the hardware (v4.1.2-302).
                    Obviously it makes the app pretty useful for any journey > 2 hours. I don't have this problem with inRoute, Apple or Google maps.
                      Here seems to be aware of this problem. The app HereWeGo has the same problem.
                      But the real question is..... When will Here fix this.
                      Arno 0
                      Arno 0
                      Simon Ferrari
                      Simon Ferrari
                      Andrew
                      Andrew
                      Mario Ivancic
                      Mario Ivancic
                        Michael 2v
                        Michael 2v
                      • Hide warnings on the map
                      • Map Layers
                        Martin White
                        Martin White
                      • Bollard trouble
