  4. A to B navigation not working
4 Posts 2 Posters 80 Views 1 Watching
  • David Bonner
    David Bonner
    David Bonner
    Yesterday I used Navigation to give me a direct route to a location from my Favourites. All worked as expected until I pressed the yellow arrow after which the map ‘home’ screen appeared with the route shown as a blue line, but with no guidance, speed limit, distance etc. In fact the navigation did not function at all during my journey, the arrow simply tracked my position as it would with the home screen.
    I checked this again today and the same thing occurs, also if you enter a destination in the search box. Navigating a pre-prepared route however appears to be functioning correctly.
    IPhone 13, Nav version 4.0.8 - 224
    • David Bonner David Bonner
      @David-Bonner, It looks like you started a by foot or bicycle route instead of a car or motor route. There is no turn-by-turn navigation for by foot and bicycle routes. Those just follow the line on the base OSM map.
      David Bonner 1 Reply Last reply
        David Bonner
        David Bonner
        David Bonner
        @Con-Hennekens Ok, I can see my mistake now! Apologies for not realising this and thanks for putting me right 👍.
          @David-Bonner, Mistakes are easily made. You are welcome!
          David Bonner
          David Bonner
          • Strange translation
            martin-phogel.de
            martin-phogel.de
            10.7k
          • Undo/Redo tool is hidden
          • Shared toggle switch
          • Crazy routing
