  4. Offline mode no longer works
36 Posts 8 Posters 383 Views 3 Watching
  • Calibos
    Calibos
    Calibos
    I used offline mode all summer for my rodtrips and everything worked wonderfully so far.
    Tomorrow I have to go 250 km from home, so I naturally took my tablet, carried out the last update of the application and downloaded my route from the road lab. I went off-grid and selected offline mode and surprise nothing works anymore. Impossible to calculate the route. the app displays a message to switch the app online to be able to carry out the calculation.
    I don't understand what's going on. Has anyone had a similar problem?
    • Calibos Calibos
      @Calibos No... I forced closed the app first. Then go into flightmode to be sure there's no live internet connection. Started the app again, selected one of my downloaded routes and pressed navigate. No problemo...
      Calibos 1 Reply Last reply
        Calibos
        Calibos
        Calibos
        wrote on last edited by Calibos
        @Rob-Verhoeff
        "I just tried again I got the following message "no route could be calculated using your offline maps to try again we need to deactivate offline navigation"
        all my maps of Europe have been present on my SD card since this summer. I navigated offline without problem in September of this year
        • Calibos Calibos
          @Rob-Verhoeff
          @Calibos Strange, have to wait until some genius comes by I think...
            Calibos
            Calibos
            Calibos
            @Rob-Verhoeff
            the only thing I've done since September is update the app to the latest version
            • Calibos Calibos
              @Rob-Verhoeff
              @Calibos said in Offline mode no longer works:
              @Rob-Verhoeff
              Same here... as you can see, completely offline:
                @Rob-Verhoeff
                Calibos
                Calibos
                Calibos
                @Rob-Verhoeff
                yes it worked perfectly before exactly like you
                • Calibos Calibos
                  @Rob-Verhoeff
                  @Calibos reboot your phone or tablet and try again?
                    Calibos
                    Calibos
                    Calibos
                    @Rob-Verhoeff
                    I have already rebooted the tablet.
                    we would say that the application no longer sees my cards
                    • Calibos Calibos
                      @Rob-Verhoeff
                      @Calibos Same as in this topic?
                      Try to initiate a route that is stored in the tablet's internal memory rather than on the memory card. If that works, you'll know what the issue is.
                        Calibos
                        Calibos
                        Calibos
                        @Rob-Verhoeff
                        I'll try
                        Is there a way to see the maps present on the SD card?
                        • Calibos Calibos
                          @Rob-Verhoeff
                          I'll try
                          @Calibos I've no idea, don't have SD-storage on an iPhone...
                          Calibos 2 Replies Last reply
                            Calibos
                            Calibos
                            Calibos
                            @Rob-Verhoeff
                            I'm re-downloading the map of the region and I'll try it later
                              Calibos
                              Calibos
                              Calibos
                              @Rob-Verhoeff
                              it works again after re-downloading the map of this region. It's good but it's worrying if an update loses the links to the downloaded maps!
                              • Calibos Calibos
                                @Rob-Verhoeff
                                Calibos
                                Calibos
                                Calibos
                                @Calibos
                                @developer
                                It would be necessary to be able to view the list of maps accessible offline. or like the background certain software a different color for the region available offline.
                                And above all understand why these cards lost their links with the application following the update
                                • paul69
                                  hi @Calibos
                                  i had a very similar issue, after downloading the latest map update.
                                  for example, i select a favourite to navigate to, and a pop up reads this cannot be calculated or similar words.
                                  i only ever use offline mode when navigating, but after the update it would not calculate any route.
                                  the only way to rectify the problem was to delete the maps then download again, I then rebooted the app and all worked perfectly.
                                  hopefully this will help others in the future.
                                  K1600 GTL
                                  iPhone 13 Pro, carpuride 702b
                                  • Calibos Calibos
                                    @Rob-Verhoeff
                                    @Calibos, What I THINK is happening is that you updated the app to a version that is no longer compatible with the offline maps you had for the previous version. I think you need to update the maps before you do anything else.
                                    There have been added some features to the app that depend on newer maps. Also the current SDK has been upgraded multiple times since summer, and often a map update is obligated after that.
                                    @Corjan-Meijerink, do you agree with this? If so it could be very helpful to do a map-check after an app-update. At the moment you only see map updates if you actively look for it in the menu. Therefore it can happen to run behind with the map version.
                                    • RetiredWingMan
                                      I agree, it appears that recent updates require updated maps.
                                      • Calibos
                                        Calibos
                                        Calibos
                                        Ok updating the map fixed the problem. Only if I hadn't checked in the evening before leaving, I simply wouldn't have been able to sail with mra this weekend.
                                        If in fact the version of the application requires a reloading of the maps then there should be an alert message when launching the app about the need to update the maps.
                                        Another point as I asked a little above would be to have a way to view the cards present in offline mode on the device because here it is impossible to know if my cards still used in the fall were lost or present on my tablet.
                                        • Calibos Calibos
                                          Maps you downloaded are marked with a check-mark.
                                          Or do I misunderstand what you mean?
                                          Calibos
                                          Calibos
                                            Rene van Maanen
                                            Rene van Maanen
                                            Helmut h
                                            Helmut h
                                            Òscar
                                            Òscar
