  4. When you stop for a break and want to start navigating
4 Posts 4 Posters 88 Views 3 Watching
  • Derek 2 Offline
    Derek 2 Offline
    Derek 2
    Today I was using the Nav next . About half way through my journey I stopped for a coffee .
    When I resumed my journey the software seemed confused and showed the total mileage as if I was starting from the beginning . As I moved off I had 2 directional arrows on the map I knew were I was going and followed my return route a few miles on the road the software recovered .
    If I had not been sure of my route it would have been very confusing and could have directed me in the wrong direction .
    Also I use my route app to make my routes and use here maps.
    When I download these in to Nav Next it tells me that the downloaded maps are saved in open street and can only open as a track which is not the case confusing
    Thank you kindly
    Derek
    RetiredWingMan Hans van de Ven MR.MRA Con Hennekens 3 Replies Last reply
    • Derek 2 Derek 2
      Thank you kindly
      Derek
      RetiredWingMan Offline
      @Derek-2 can you provide a screen shot of the error message when you try to open a downloaded route?
      • Derek 2 Derek 2
        Thank you kindly
        Derek
        @Derek-2
        You can stop the navigation by clicking on the 3 dots and then choosing Stop navigation. On the screen you will then get the option to resume navigation. If you choose no there, the route will be closed. If you leave this question, you can press the button after the stop to restart the navigation of the location where you are.
        • Derek 2 Derek 2
          Thank you kindly
          Derek
          @Derek-2, What phone do you use? Were you using Apple Carplay by any chance?
          It;s pretty easy to stop and start navigating all over. Long-press the first waypoint ahead of the route to pick up from where you are.
          I suspect that the route you are opening has been downloaded before that function was implemented. If you delete it and download it again it will be okay.
          Derek 2
          Derek 2
          • The slow death of Zumo...
          • Welke instelling
            1.1k
            Carl Lee
            Carl Lee
          • Rejoining routes
            Terry Cox 0
            Terry Cox 0
            Karl-Heinz Schwendner
          • New Zealand Touring Group
