  3. HERE issue regarding seasonal closures
8 Posts 4 Posters 3.1k Views 5 Watching
  • Corjan Meijerink Offline
    Hi all! 🙂
    Over the last days / weeks we got some reports that the seasonal closures in the HERE map were not working as expected. We've investigated the issue and I've been in contact with our local HERE partner. Today I received confirmation that the issue is with HERE and they will look into it with priority.
    Unfortunately we cannot do anything right now to solve the problem. We do however have two recommendations:
    • Use more waypoints. By placing waypoints on the closed road, it might force the route to use that road.
    • Try other avoid options. Sometimes a nearby tunnel allows a suitable alternative so enabling the "avoid tunnels" option from the toolkit could also help in that specific scenario. Be aware that this can have side effects for the other part of the route as it will try to avoid all tunnels on the route.
    We'll let you know when the issue has been solved! 🙂 Sorry for the inconvenience.
    Bill Hoxworth 1 Reply Last reply
    • Hubert Thoring Offline
      Danke für die Info !!!!
      • Greyhound 0 Offline
        Greyhound 0 Offline
        Greyhound 0
        Danke für die Info!
        • Hans van de Ven MR.MRA Hans van de Ven MR.MRA referenced this topic on
          Hi all! 🙂
          Bill Hoxworth Offline
          Bill Hoxworth
          @Corjan-Meijerink Thanks for all your help, but has HERE made any progress with the fix for this issue, I am trying to plan a route through Switzerland and given the current issues with the map, it is impossible due to the none function of the seasonal closures choice. Once again, thanks for your help.
          Kind Regards,
          Bill UK
          • Bill Hoxworth Bill Hoxworth
            Kind Regards,
            Bill UK
            @Bill-Hoxworth thanks for pinging me 🙂 I’ve reached out to HERE (again…)
              Bill Hoxworth
              @Corjan-Meijerink Good morning. This issue with seasonal closures is a serious one, if you are a Garmin owner, the issue effectively limits your use of the map programme to 3/4months of the year. This is due to the seasonal closures issue. I have tried both your suggestions for a work around, neither will suffice and they just don't work. As you will now, I have used the programme for a good number of years and have a lot of experience using your product. I am therefore faced with some choices. Do I stick with a product I am paying 35gbp per year, but can only have full use for 3/4 months, do I purchase a Tom Tom system, well they are 400 gbp, so that is unlikely. I have no doubt HERE will be taking money from you to use their product. Can I therefore suggest the following. Whoever it is you are "reaching" out to, reach out with your metaphorical boot and really shake the department up. Tell them you are unhappy with their response and really come down hard on them. If you guys are not being charged by HERE, then there is very little you can do, but lose customers from your product. Please do not take this personally, I am just very, very unhappy with a situation, where it appears, no progress is being made.
              Kind Regards
              Bill
                Update! 🎉
                https://forum.myrouteapp.com/topic/4119/seasonal-closure-issue-solved
                Greyhound 0 1 Reply Last reply
                  Update! 🎉
                  Greyhound 0 Offline
                  Greyhound 0 Offline
                  Greyhound 0
                  wrote on last edited by Greyhound 0
                  Thank you for your information 👍 😊
                  Bill Hoxworth
                  Bill Hoxworth
                  Greyhound 0
                  Greyhound 0
                  • Carpuride scherm vast
                    De Ploey Georges
                    De Ploey Georges
                    1.2k
                  • Camperroutes
                    De Ploey Georges
                    De Ploey Georges
                    14.0k
                  • Not a great route choice
                    Philip Verbeek
                    Philip Verbeek
                  • (Android Auto) Zoom/Steuerung blendet aus und lässt sich nicht per Lenkerschalter reaktivieren.
