  3. Backcountry Discovery Routes (BDR) Import Problem
5 Posts 4 Posters 1.2k Views 1 Watching
  • Stephen Garrison
    Stephen Garrison
    Stephen Garrison
    wrote on last edited by Stephen Garrison
    I'm new to MyRoute-app and have tried to import the Colorado BDR gpx file (and other BDR files) and the routes do not import properly. All of the BDRs are popular and great to ride here in the USA so I really want to make sure MyRoute-app is working correctly with them. The waypoints points are out of order when I import. Any help is appreciated.
    https://ridebdr.com/cobdr/
    Stephen
    TorqueRider flamingm0e 2 Replies Last reply
    • Stephen Garrison Stephen Garrison
      Stephen
      @Stephen-Garrison
      The waypoints do indeed get a wrong sequence number. They are placed in alphabetical order.
      A solution is laborious I'm afraid.
      I did that like this:
      Downloaded the file from ridebdr.com
      Map created in MRA and uploaded there.
      First opened the <Route> tab and then did another upload with the <Route-track> tab
      Then opened the route file in MRA. Then the route and the waypoints are visible.
      Then add the Route-Track files via the item "Routes" in the right column.
      When you have done that, click again on the item "Waypoints" in the right column and then drag the waypoints in the right order.
      (a lot of work but I don't see a better solution 🙂 )
      • TorqueRider TorqueRider
        @Stephen-Garrison
        @Jack-van-Tilburg Can't you just import the route-track and then use "Edit route-track" to create the route?
          @Herko-ter-Horst
          It's absolutely a possibility. But then you have to do extra work to include the waypoints in that route.
            Stephen
            flamingm0e
            flamingm0e
            flamingm0e
            @Stephen-Garrison I wouldn't bother with this.
            Last year I went through this entire process of painstakingly recreating the COBDR in MRA. It took me a couple of days. The old navigation app fell flat on its face 15 minutes into the trip.
            You're much better off using another app for navigating the COBDR until NEXT is completed.
            I used Drive Mode Dashboard 2 to follow the tracks on my Carpe Iter tablet, and ran Gaia on my phone as a secondary view and for more information.
            flamingm0e
            flamingm0e
            Stephen Garrison
            Stephen Garrison
            • Kaart niet zichtbaar
              Lluís Casals
              Lluís Casals
            • Xpert overlay not clear
            • Google maps
              Ed Bos 0
              Ed Bos 0
            • Navigation Next op telefoon wel naar v6 maar Android 14 systeem op motor niet
              Jaap van Maanen
              Jaap van Maanen
            • RouteXpert display on the map
              Corrado Miniati 0
              Corrado Miniati 0
              Corrado Miniati 0
              Corrado Miniati 0
