  3. Zumo XT MAC gpx1.2
Zumo XT MAC gpx1.2
14 Posts 4 Posters 2.3k Views 2 Watching
  • Johan Gustavssonundefined Offline
    Johan Gustavsson
    Hello!
    Is it only me having problem to export with gpx1.2 with mac, there is no option to select 1.2?
    With my PC it works fine.
    • Johan Gustavssonundefined Johan Gustavsson
      Hello!
      Jack van Tilburg
      @johan-gustavsson
      Will this help you?
      Garmin Zumo XT <-> Mac... (click)
      Johan Gustavssonundefined 1 Reply Last reply
        @johan-gustavsson
        Will this help you?
        Johan Gustavsson
        @jack-van-tilburg I have Android file tranfer installed and I can copy files to the XT.
        But I wan´t to use cable and send via connector.
        Jack van Tilburgundefined Reinhard-32undefined 2 Replies Last reply
          Jack van Tilburg
          @johan-gustavsson
          Not funny!
          Look at this instruction:
          (Source)
          Exporting a gpx 1.2 route to your Garmin Zumo
          A gpx 1.2 file consists of waypoints and the track with possibly poi's (points of interest). Exporting to your Garmin follows the same procedure as gpx 1.1, only choose Garmin Zumo (GPX 1.2) in the connector. You can now also import the route and you will see the route in the 'Travel Planner'. The difference is that no formation points are now shown, only the via points in the form of orange flags. If you click on the 'Map', you will only see the flags. The route between the flags is a track and that is very different from navigating via the route, more about that below.
          But this is what I see:
          No GPX 1.2
            Reinhard-32undefined Offline
            Reinhard-32
            @johan-gustavsson I have an iMac and it is not possible to send Data from MRA via connector to the ZumoXT.
            Kindly regards
            Reinhard
              Jack van Tilburg
              @reinhard-32 @Johan-Gustavsson
              Michel van Hagen's Blog does not describe an exception for Mac.
              Maybe a good reason to create a ticket in the 'Support' section?
                Hans van de Ven MR.MRAundefined Online
                @jack-van-tilburg
                I think it is because you can only have 1 open system connected to the Mac.
                Filetransfer is 1
                Connector is 2
                  @jack-van-tilburg
                  Filetransfer is 1
                  Connector is 2
                  Jack van Tilburg
                  @hans-van-de-ven-mra-master
                  That could be.
                  But I use a pre M1 Mac and don't see the choice for GPX 1.2.
                  (I'm pretty sure I used it for my BMW Nav XI)
                  I only have an old Garmin Zumo 590 so can't test 😞
                    That could be.
                    @jack-van-tilburg
                    Then create a support ticket that gpx 1.2 is not available in the connector on a Mac
                      @jack-van-tilburg
                      Jack van Tilburg
                      I don't think it's helpful if I do that because I'm not a user of this feature.
                      Good action for @Johan-Gustavsson of @Reinhard-32.
                      Reinhard-32undefined 1 Reply Last reply
                        Reinhard-32
                        @jack-van-tilburg In the meantime I have opened a ticked according this problem.
                        Kindly regards
                        Reinhard
                        Jack van Tilburgundefined Johan Gustavssonundefined 2 Replies Last reply
                          Jack van Tilburg
                          @reinhard-32 👍
                            Johan Gustavsson
                            @reinhard-32 👍
                              @johan-gustavsson
                              Not funny!
                              (Source)
                              No GPX 1.2
                              Johan Gustavsson
                              @jack-van-tilburg 👍
                              Reinhard-32
                              Jack van Tilburg
                              Johan Gustavsson
                                973
                              • batterij verbruik
                                CD130undefined
                              • Flitsmeister
                              • In bibliotheek: rondrit vs route optie
                              • Carpuride
                                guenniguenzelsenundefined
                                guenniguenzelsen
                              • WEB-version of From-To, heavily curved, avoid highway
                              • GPS positie freeze
                                Mark Vroomenundefined
                                Mark Vroomen
