  3. 2019 GTS Boom Box Export
6 Posts 3 Posters 906 Views 1 Watching
  • David Hetheringtonundefined Offline
    David Hetherington
    Help
    I’m having a problem exporting to USB.
    I click on 2019 Track, then save as, I go to where it has been uploaded and move into the USB.
    The file size is only 3kb
    Connect to GTS Boom Box click on select all, and the import.
    After a second, I get unable to import.
    I click on saved on the Boom Box it shows the file but only the start addresses and finish address, and It calculates the route from my home address, via the start address to the destination ignoring my saved routes.
    Frustrating when destinations are in the alps.
    I am using the same USB stick as last year which worked then.
    Can anyone help
    I am not a techno person so it has to be simple.
    • David Hetheringtonundefined David Hetherington
      Help
      Can anyone help
      Jack van Tilburg
      @david-hetherington
      Would you please post a link to the respective route here.
      Make sure that the privacy setting of the route is set to "public".
      I assume that you normally have no problems loading a route in your boombox.
      David Hetheringtonundefined 1 Reply Last reply
      • Douglas McBeanundefined Offline
        Douglas McBean
        David,
        Do not choose (SELECT ALL) highlight the next one down for importing on the bike. It will have a waypoint and a destination flag. Import and this should work
        Doug
          @david-hetherington
          David Hetherington
          @jack-van-tilburg
          Hi not sure how to post link but will have a go
          • Douglas McBeanundefined Douglas McBean
            David,
            Doug
            David Hetherington
            @douglas-mcbean
            Hi Doug
            I will have a go when able as time short for the next couple of weeks.
            In the end I saved to the computer, then download the Harley router and loaded it on that. Then saved it again and transferred on to memory stick, and then it did load.
            The only one day that won’t load is one that could be affected by seasonal closures.
            It’s ok on the planner but loaded onto Harley one it reroutes it.
            I will have ago at your suggestion when back home. Thanks
              @jack-van-tilburg
              Jack van Tilburg
              @david-hetherington said in 2019 GTS Boom Box Export:
              @jack-van-tilburg
              Open the route in the Routelab;
              Select 'Route information' in the left-hand column;
              Click on 'Privacy"
              Now click on the three dots behind the route name in the route library to get to the "More options" window.
              Jack van Tilburg
              Douglas McBean
              David Hetherington
              • Expand
              • Routepunten
              • Possibly a average speed camera bug
                Herman Veldhuizenundefined
                1.9k
              • Sealevel
                Christian Feursteinundefined
                Christian Feurstein
                Cleoundefined
                Cleo
              • Altijd weer terug naar startpunt
                35.1k
