  3. Total ride time different when exporting to Garmin
19 Posts 6 Posters 3.2k Views 1 Watching
  • PAD 0 PAD 0
    @paul-hulsegge Could you provide links to the routes, please? That is a big discrepancy between journey times and the Garmin one seems very pessimistic for that sort of distance. And could you state which BMW-Garmin device you are using too?
    paul hulsegge
    paul hulsegge
    paul hulsegge
    @pad-0 Thx for your reply. at this moment I have the basic MRA. basis other replies it seems I have to move to gold for HERE. Will be a serious option for me now.
    I have the BMW Navigator VI with regular updates.
    I 1st made my trip in MRA. & after downloading to NAvigator, I made sure my intermediate points were exacrly the same. Even zooming in, my roads I selected are the same.
    Drabslab 1 Reply Last reply
    • paul hulsegge paul hulsegge
      @paul-hulsegge Good idea to become "gold". But Pad 0 is right as well, there is avery bgi difference btween the time calcualted by MRA (even when it is the free version) and Garmin.
      If you make your route public we could have a look at it.
      PAD 0 paul hulsegge 2 Replies Last reply
      • Drabslab Drabslab
        PAD 0
        PAD 0
        PAD 0
        Yes, a subscription to the Routeplanner app makes for a very useable tool. My thinking in asking for route links is that, due to potential discrepancies in road placement between different map layers, you might have inadvertently ended up with a waypoint or waypoints on the wrong side of a dual carriageway or some such. That could significantly increase route length and still potentially go unnoticed.
        I don’t think the sat nav in question introduces much by way of settings that could affect trip duration. That would be more in BaseCamp territory, but that's out of the equation it seems.
        • PAD 0 PAD 0
          @pad-0 Often, things like this have a very simple explanation, it is the finding of that explanation that is difficult 🙂
          Hene, my request to Paul to show us the route so we can check.
          PAD 0 1 Reply Last reply
          • Drabslab Drabslab
            PAD 0
            PAD 0
            PAD 0
            @drabslab We’re on the same page in that!
            • PAD 0 PAD 0
              paul hulsegge
              paul hulsegge
              paul hulsegge
              @pad-0 I made below public (I hope 😉 )
              https://www.myrouteapp.com/route/open/5538378
              https://www.myrouteapp.com/route/open/5544459
              • Drabslab Drabslab
                paul hulsegge
                paul hulsegge
                paul hulsegge
                @drabslab I made below public (I hope 😉 )
                  @paul-hulsegge
                  Hello Paul,
                  Use the Here-map instead of the OSM map (Green line is the Here-line)
                  paul hulsegge 1 Reply Last reply
                    @paul-hulsegge
                    Hello Paul,
                    paul hulsegge
                    paul hulsegge
                    paul hulsegge
                    @hans-van-de-ven-mra-master ok thanks for the tip. I will change and effect effect towards Navigator VI
                      PAD 0
                      PAD 0
                      PAD 0
                      wrote on last edited by PAD 0
                      @paul-hulsegge A number of waypoints are positioned off road to a greater or lesser extent, particularly in the first route. That said, with two exceptions, they don’t appear to be affecting either. Route 1 / No. 10 causes a brief excursion part way down a street before returning (possibly deliberate?) Route 1 / No. 26 causes the route to do a full tour of a roundabout before carrying on its way… Hardly sufficient to cause significant problems. Not on that map layer anyway. But that may not be the case in transfer to your sat nav. Short of me loading the routes onto my Garmin, I can’t really comment further, but I would suggest having a good sequential look at the route as it has transferred. Maybe connect the device to a computer and view the routes in BaseCamp and, if there are any glitches, correct them?
                      Certainly for Garmin users, being able to use the Here layer in MRA Routeplanner makes subscribing worthwhile in itself, but there are numerous other advantages too and I thoroughly recommend it.
                      • PAD 0 PAD 0
                        paul hulsegge
                        paul hulsegge
                        paul hulsegge
                        @pad-0 thx for yr review and advices. I will follow-up Rgds
                        paul hulsegge
                        paul hulsegge
                        PAD 0
                        PAD 0
                          11.9k
                        • Issues on one-way streets when reversing routes
                        • Route line is not easy to follow on map
                        • F004 MRA Navigation Error
                        • Probleem met eigen Stay
                          Albert van den Elsen
                        • POI functie 'strict'
