  3. Roundtour Issue
Roundtour Issue
3 Posts 2 Posters 662 Views 1 Watching
  • daz 2
    daz 2
    daz 2
    Hi Guys Just wondering is it me or is it myrouteapp web is the problem?? if I create a route from scratch and transfer it using the connector app it transfers perfectly to my garmin nuvi 765 import the new route from my data folder and all is good but if I use roundtour it transfers to the device ( I can physically the gpx file) but is not recognized in the data folder when I plug out the device. Also what I have noticed is there is no country emblem on roundtour routes,( in my routes folder) where as there is on a route that I create. Any thoughts ?? I have allowed MRA access to my location on browser also I tried firefox browser as well with the same result. Thanks Dave
    • daz 2 daz 2
      @daz-2
      Hi @daz-2 , did you check the route points, and did you choose the Here-map after you saved the route?
      The round tour generator uses the OSM map and that one is different from the here-map.
      daz 2 1 Reply Last reply
        @daz-2
        daz 2
        daz 2
        daz 2
        @hans-van-de-ven-mra-master Thank you Hans you were indeed correct I had the maps setting on Open street Maps .I'll make sure its on the correct setting in future ,thank you for your speedy reply my friend .David
        daz 2
        daz 2
          martin-phogel.de
          martin-phogel.de
          12.0k
        • Issues on one-way streets when reversing routes
        • Route line is not easy to follow on map
        • F004 MRA Navigation Error
        • Probleem met eigen Stay
          Albert van den Elsen
        • POI functie 'strict'
