<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Changing Point A in A to B navigation to test distances and routes]]></title><description><![CDATA[<p dir="auto">Hi,</p>
<p dir="auto">I would like to be able to test time/distance in A to B plotting/routes.</p>
<p dir="auto">The app does not appear to allow me to change the Start location of an A to B route. It always uses my current location. I would like to be able to change this.</p>
<p dir="auto">eg. In the Attached picture the A to B route is from my home to Montriond. Would like to be able to click on current location and change, for instance to Geneva Airport. So I can see the time it would take... Their has been a land side on the route up to Montriond so wanted to check alternative routes and times.</p>
<p dir="auto">Want to do a quick check and not set up route to do a simple check.</p>
<p dir="auto">Hope this makes sense?</p>
<p dir="auto"><img src="/assets/uploads/files/1795540638377-fullsizeoutput_6044.jpeg" alt="fullsizeoutput_6044.jpeg" class=" img-fluid img-markdown" width="1290" height="2796" /></p>
]]></description><link>https://forum.myrouteapp.com/topic/13018/changing-point-a-in-a-to-b-navigation-to-test-distances-and-routes</link><generator>RSS for Node</generator><lastBuildDate>Tue, 24 Nov 2026 19:22:22 GMT</lastBuildDate><atom:link href="https://forum.myrouteapp.com/topic/13018.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 24 Nov 2026 18:46:10 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Changing Point A in A to B navigation to test distances and routes on Tue, 24 Nov 2026 19:03:29 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/andy-smith-5" aria-label="Profile: Andy-Smith-5">@<bdi>Andy-Smith-5</bdi></a> In this case, you can select ‘Add stop’ and enter your chosen location.<br />
Once you have added the new location as a stop, you can delete your home address.</p>
<p dir="auto"><img src="/assets/uploads/files/1795547007062-33868.png" alt="33868.png" class=" img-fluid img-markdown" width="864" height="1939" /></p>
]]></description><link>https://forum.myrouteapp.com/post/90273</link><guid isPermaLink="true">https://forum.myrouteapp.com/post/90273</guid><dc:creator><![CDATA[Peter Zehentreiter]]></dc:creator><pubDate>Tue, 24 Nov 2026 19:03:29 GMT</pubDate></item></channel></rss>
