<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Add stops in the 'Information' menu]]></title><description><![CDATA[<p dir="auto">Hi,<br />
The 'Information' section offers a very useful arrival time feature, which tells you whether your departure time needs to be adjusted to meet your set arrival time.<br />
On the other hand, if you leave early it suggests a later departure time than the one you set in order to match that arrival time.<br />
In this case it would be great also to add the option to insert breaks along the route while keeping your desired departure time.<br />
My suggestion is to add an 'Add stops' button that opens a menu where you can select which shape points to convert into via points with dedicated breaks.<br />
It could even offer a limited selection, for example, up to 10 shaping points.</p>
<p dir="auto"><img src="/assets/uploads/files/1795005304537-1.jpg" alt="1.jpg" class=" img-fluid img-markdown" width="1706" height="1261" /></p>
<p dir="auto">Thanks</p>
]]></description><link>https://forum.myrouteapp.com/topic/12852/add-stops-in-the-information-menu</link><generator>RSS for Node</generator><lastBuildDate>Wed, 18 Nov 2026 14:56:30 GMT</lastBuildDate><atom:link href="https://forum.myrouteapp.com/topic/12852.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 18 Nov 2026 12:35:20 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Add stops in the 'Information' menu on Wed, 18 Nov 2026 13:54:36 GMT]]></title><description><![CDATA[<p dir="auto">Not for now</p>
]]></description><link>https://forum.myrouteapp.com/post/89803</link><guid isPermaLink="true">https://forum.myrouteapp.com/post/89803</guid><dc:creator><![CDATA[Corjan Meijerink]]></dc:creator><pubDate>Wed, 18 Nov 2026 13:54:36 GMT</pubDate></item></channel></rss>
