<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Website update - Send to your phone, POIs in clubs, search on the map and more]]></title><description><![CDATA[<p dir="auto">Hi everyone! <img src="https://forum.myrouteapp.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f44b.png?v=06c51928fc7" class="not-responsive emoji emoji-android emoji--wave" style="height:1.4em;width:auto;vertical-align:middle" title=":wave:" alt="👋" /></p>
<p dir="auto">Another website update is live, and once more a lot of it comes from your forum topics <img src="https://forum.myrouteapp.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f4aa.png?v=06c51928fc7" class="not-responsive emoji emoji-android emoji--muscle" style="height:1.4em;width:auto;vertical-align:middle" title=":muscle:" alt="💪" /> Here's what changed since Friday's update.</p>
<h2>New</h2>
<ul>
<li><strong>Send to my phone.</strong> Send a route or tracklog to one of your own phones, from the share popup or the planner's menu. Your phone gets a notification, and a tap opens it in the app.</li>
<li><strong>POIs in clubs and events.</strong> A club or event has a POIs tab where POI groups can be linked. Members can open them, show them on the planner map and copy POIs to their own. A group stays with its owner, and their changes show straight away.</li>
<li><strong>Search on the map.</strong> The search box shows its matches on the map while you type, a row and its pin light each other up, and "Show all on the map" frames every match. The box stays open while you pan, and Discover no longer covers it.</li>
<li><strong>Name or brand in Discover.</strong> Find every McDonald's on the map, or only those among the fast food you picked.</li>
<li><strong>Duplicate a trip</strong> to plan an alternative with the same days, dates and nights.</li>
<li><strong>The trip builder offers to fill in the days</strong> between two dated days, so every day counts and the nights run on.</li>
<li><strong>Show where your day limit runs out.</strong> The planner flags a route as soon as it passes your day limit, in hours or kilometres, and "Show where" marks the spot on the map.</li>
<li><strong>When a route can't be calculated</strong>, the planner finds the waypoint that causes it and marks it in the message, the waypoint list and on the map.</li>
<li><strong>Weather on scenic routes.</strong> The scenic route generator shows the weather along each route option, with the weather map on top. The options also show their distance and riding time.</li>
<li><strong>Photos with friends.</strong> The Photos page can show your friends' photos beside yours, and each tracklog's photos start with a tile of its map. "On this day" can remind you of what you took on this day in earlier years, and you can turn that off in your notification settings.</li>
<li><strong>Collapse all.</strong> One tab, or Shift+C, closes every open section in the planner sidebar.</li>
<li><strong>Maintenance:</strong> the usual intervals are filled in and you can type your own numbers in place. A job of your own gets its own name under Other, in the logbook, reminders and service book.</li>
<li><strong>The star on a vehicle in your garage</strong> makes it the default for its travel mode.</li>
</ul>
<h2>Improvements and changes</h2>
<ul>
<li>Start route here on a route from A to B: Keep direction now turns the route like a loop, so the waypoint becomes 1 and the rest follow in order. Each choice says where the route then ends.</li>
<li>The calculator also shows the time with the pauses at the waypoints in between.</li>
<li>The two compare tools have their own names: Compare engines in the toolkit, and Side by side for routes and tracklogs you show next to yours.</li>
<li>The route plan PDF, Align engines and Avoid this road now follow a route's segments and straight legs, so their distance, time and directions match the planner.</li>
<li>Discover's Historic finds memorials, batteries and war cemeteries, and Museum finds more museums. Search pins look sharper too.</li>
<li>A trip day shows its route's description as Route notes while nothing is written about the day yet.</li>
<li>A trip's action bar keeps Share, Publish and Edit in view and folds the rest into one menu.</li>
<li>Every tile under Your stats on the home page opens the page behind it.</li>
<li>Club and event routes name their owner.</li>
<li>Daylight lists the waypoints you reach in the dark by their pin and number, like the waypoint list.</li>
<li>Route defaults in Settings name the vehicles whose own settings replace them.</li>
<li>Event attendance shows how many people are invited but haven't joined yet.</li>
<li>The map picker lists Google's maps first among the other makers' maps, and opens on the map you're using.</li>
<li>Search finds your own Unlisted routes and tracklogs, offers Show more under every kind of result, and is much faster.</li>
<li>The library's overview map frames most of your lines and says which far-away ones it leaves out.</li>
<li>Route warnings show their whole explanation.</li>
<li>On a phone or upright tablet the planner offers to continue your unsaved route, and an unsaved route is kept the moment you switch apps.</li>
<li>The eye in the planner's library brings a route or tracklog into view when it's off screen, and routes made with Split into days or Trim show in that list straight away.</li>
<li>You can swipe the map sheet's handle to fold or open it.</li>
</ul>
<h2>Fixed</h2>
<ul>
<li>A write-up with photos side by side, as the classic website made them, no longer loses its text when you save it in the editor.</li>
<li>Switching maps while one is still loading no longer crashes the planner.</li>
<li>Pulling down on a page in Safari on iPhone no longer reloads it.</li>
<li>A route starting at Tanger Med reads Moroccan time instead of Spanish time.</li>
<li>The month and year lists in the date picker are readable in the dark theme on Windows.</li>
<li>The Settings page no longer scrolls on past its end, and the Photos page no longer moves sideways on a phone.</li>
</ul>
<p dir="auto">That's it! Thanks again for all your feedback <img src="https://forum.myrouteapp.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f64f.png?v=06c51928fc7" class="not-responsive emoji emoji-android emoji--pray" style="height:1.4em;width:auto;vertical-align:middle" title=":pray:" alt="🙏" /></p>
<p dir="auto">Cheers,<br />
Corjan</p>
]]></description><link>https://forum.myrouteapp.com/topic/12825/website-update-send-to-your-phone-pois-in-clubs-search-on-the-map-and-more</link><generator>RSS for Node</generator><lastBuildDate>Tue, 17 Nov 2026 17:43:31 GMT</lastBuildDate><atom:link href="https://forum.myrouteapp.com/topic/12825.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 17 Nov 2026 16:55:56 GMT</pubDate><ttl>60</ttl></channel></rss>
