<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[F034 Maintenance plan and cycles wrong?]]></title><description><![CDATA[<p dir="auto">The base should be adjustable or I just can't find the button for it, since I drive an R1250GS, the stored service plan doesn't fit at all.</p>
<p dir="auto">The original seems to be from a Honda CRF1100L AT or ?</p>
<p dir="auto">I would expect an adaptable list.</p>
<p dir="auto"><img src="/assets/uploads/files/1794816368339-img_2999.png" alt="IMG_2999.png" class=" img-fluid img-markdown" width="1170" height="2532" /></p>
<p dir="auto"><img src="/assets/uploads/files/1794816582542-img_3003.jpeg" alt="IMG_3003.jpeg" class=" img-fluid img-markdown" width="1170" height="1672" /></p>
]]></description><link>https://forum.myrouteapp.com/topic/12775/f034-maintenance-plan-and-cycles-wrong</link><generator>RSS for Node</generator><lastBuildDate>Mon, 16 Nov 2026 09:56:40 GMT</lastBuildDate><atom:link href="https://forum.myrouteapp.com/topic/12775.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 16 Nov 2026 08:08:10 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to F034 Maintenance plan and cycles wrong? on Mon, 16 Nov 2026 09:38:48 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/corjan-meijerink" aria-label="Profile: corjan-meijerink">@<bdi>corjan-meijerink</bdi></a></p>
<p dir="auto">There is not "free text" option to add any kind of maintenance or notification.<br />
Perhaps "other" can add a free text to database that user can fill in.</p>
<p dir="auto">Regards,</p>
]]></description><link>https://forum.myrouteapp.com/post/89575</link><guid isPermaLink="true">https://forum.myrouteapp.com/post/89575</guid><dc:creator><![CDATA[Lluis Arasanz]]></dc:creator><pubDate>Mon, 16 Nov 2026 09:38:48 GMT</pubDate></item><item><title><![CDATA[Reply to F034 Maintenance plan and cycles wrong? on Mon, 16 Nov 2026 09:24:02 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/corjan-meijerink" aria-label="Profile: Corjan-Meijerink">@<bdi>Corjan-Meijerink</bdi></a> It’s surely simple, but I must be having an off day—I just can’t figure out how to customize a maintenance task.<img src="https://forum.myrouteapp.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f60a.png?v=06c51928fc7" class="not-responsive emoji emoji-android emoji--blush" style="height:1.4em;width:auto;vertical-align:middle" title=":blush:" alt="😊" /> <img src="https://forum.myrouteapp.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f60a.png?v=06c51928fc7" class="not-responsive emoji emoji-android emoji--blush" style="height:1.4em;width:auto;vertical-align:middle" title=":blush:" alt="😊" /></p>
<p dir="auto"><img src="/assets/uploads/files/1794821001031-e43e1946-e4e8-4574-80a4-e9d00d72f4f6-image.jpeg" alt="image.jpeg" class=" img-fluid img-markdown" width="613" height="499" /></p>
<p dir="auto">Regards.</p>
<p dir="auto">Òscar</p>
]]></description><link>https://forum.myrouteapp.com/post/89571</link><guid isPermaLink="true">https://forum.myrouteapp.com/post/89571</guid><dc:creator><![CDATA[Òscar]]></dc:creator><pubDate>Mon, 16 Nov 2026 09:24:02 GMT</pubDate></item><item><title><![CDATA[Reply to F034 Maintenance plan and cycles wrong? on Mon, 16 Nov 2026 09:09:38 GMT]]></title><description><![CDATA[<p dir="auto">Add it and edit it afterwards.</p>
]]></description><link>https://forum.myrouteapp.com/post/89567</link><guid isPermaLink="true">https://forum.myrouteapp.com/post/89567</guid><dc:creator><![CDATA[Corjan Meijerink]]></dc:creator><pubDate>Mon, 16 Nov 2026 09:09:38 GMT</pubDate></item><item><title><![CDATA[Reply to F034 Maintenance plan and cycles wrong? on Mon, 16 Nov 2026 09:02:31 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/corjan-meijerink" aria-label="Profile: Corjan-Meijerink">@<bdi>Corjan-Meijerink</bdi></a> How can I add a custom checkpoint?</p>
<p dir="auto"><img src="/assets/uploads/files/1794819630936-6403bcef-e203-4f68-abdf-d9f9ced5ac39-image.jpeg" alt="image.jpeg" class=" img-fluid img-markdown" width="583" height="689" /></p>
<p dir="auto"><img src="/assets/uploads/files/1794819662892-27789248-9dd1-4881-a9d5-a72b1465428c-image.jpeg" alt="image.jpeg" class=" img-fluid img-markdown" width="568" height="612" /></p>
<p dir="auto">Regards!</p>
]]></description><link>https://forum.myrouteapp.com/post/89564</link><guid isPermaLink="true">https://forum.myrouteapp.com/post/89564</guid><dc:creator><![CDATA[Òscar]]></dc:creator><pubDate>Mon, 16 Nov 2026 09:02:31 GMT</pubDate></item><item><title><![CDATA[Reply to F034 Maintenance plan and cycles wrong? on Mon, 16 Nov 2026 08:54:32 GMT]]></title><description><![CDATA[<p dir="auto">The service plan isn't from a Honda. It's a general list of typical intervals for motorcycles, which is why the dialog asks you to check your own manual. Here's how to make it fit your R1250GS:</p>
<ul>
<li>In "Set up a service plan" you can untick the lines that don't apply (for example "Clean &amp; lube chain" on a shaft drive).</li>
<li>Afterwards you can edit each reminder (interval in km and/or months) or delete it. With "Add reminder" you can add your own, for example final drive oil or brake fluid on BMW's schedule.</li>
</ul>
<p dir="auto">About the odometer: the tracklogs are only the starting point. With "Adjust" you enter the real reading, as you already did with 50,600 km. From that reading on, new tracklogs add to it. You can correct it again at any time, for example at every service.</p>
]]></description><link>https://forum.myrouteapp.com/post/89562</link><guid isPermaLink="true">https://forum.myrouteapp.com/post/89562</guid><dc:creator><![CDATA[Corjan Meijerink]]></dc:creator><pubDate>Mon, 16 Nov 2026 08:54:32 GMT</pubDate></item><item><title><![CDATA[Reply to F034 Maintenance plan and cycles wrong? on Mon, 16 Nov 2026 08:24:13 GMT]]></title><description><![CDATA[<p dir="auto">Note: I find it difficult that the driven km in the first step are only derived from the tracklog records, I have now found something about it but ....</p>
<p dir="auto">When I click on maintenance, the possibility comes to set something.</p>
<p dir="auto"><img src="/assets/uploads/files/1794817343989-img_3008.png" alt="IMG_3008.png" class=" img-fluid img-markdown" width="1170" height="2532" /></p>
<p dir="auto"><img src="/assets/uploads/files/1794817418226-img_3006.png" alt="IMG_3006.png" class=" img-fluid img-markdown" width="1170" height="2532" /></p>
]]></description><link>https://forum.myrouteapp.com/post/89552</link><guid isPermaLink="true">https://forum.myrouteapp.com/post/89552</guid><dc:creator><![CDATA[Hubert Thoring]]></dc:creator><pubDate>Mon, 16 Nov 2026 08:24:13 GMT</pubDate></item></channel></rss>
