<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[POI Removal Method from the Routing Menu]]></title><description><![CDATA[<p dir="auto">If I add a POI to the map and later want to remove it, the only method I have found is to click the "Remove from Route" button located at the bottom-right of the POI menu on the right side of the screen.<br />
However, I could not find a way to remove the same POI directly from the routing menu on the left side of the screen.<br />
As is already possible with waypoints, would it be possible to remove POIs directly from the routing menu simply by selecting them and pressing the Delete key on the keyboard?<br />
This would make route editing more intuitive and provide a consistent user experience between waypoints and POIs.</p>
<p dir="auto"><img src="/assets/uploads/files/1794256572700-1-resized.jpg" alt="1.jpg" class=" img-fluid img-markdown" width="2291" height="1259" /></p>
]]></description><link>https://forum.myrouteapp.com/topic/12525/poi-removal-method-from-the-routing-menu</link><generator>RSS for Node</generator><lastBuildDate>Tue, 10 Nov 2026 01:46:47 GMT</lastBuildDate><atom:link href="https://forum.myrouteapp.com/topic/12525.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 09 Nov 2026 20:36:20 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to POI Removal Method from the Routing Menu on Mon, 09 Nov 2026 21:18:51 GMT]]></title><description><![CDATA[<p dir="auto">Thank you for the feedback.<br />
Using the Delete key on the keyboard, from the routing menu on the left, shouldn't it be possible to remove it from the route without deleting it from the POI list?</p>
]]></description><link>https://forum.myrouteapp.com/post/88652</link><guid isPermaLink="true">https://forum.myrouteapp.com/post/88652</guid><dc:creator><![CDATA[Corrado Miniati]]></dc:creator><pubDate>Mon, 09 Nov 2026 21:18:51 GMT</pubDate></item><item><title><![CDATA[Reply to POI Removal Method from the Routing Menu on Mon, 09 Nov 2026 21:10:39 GMT]]></title><description><![CDATA[<p dir="auto">To remove a POI from a route, without deleting it entirely, click on the POI and then click "Remove from route" at the bottom right of the POI dialog.  Do not click edit unless you want to delete the POI entirely.</p>
]]></description><link>https://forum.myrouteapp.com/post/88651</link><guid isPermaLink="true">https://forum.myrouteapp.com/post/88651</guid><dc:creator><![CDATA[smfollen 0]]></dc:creator><pubDate>Mon, 09 Nov 2026 21:10:39 GMT</pubDate></item></channel></rss>
