<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Website update - Keyboard shortcuts, route status, every Discover category and more of your feedback]]></title><description><![CDATA[<p dir="auto">Hi everyone! <img src="https://forum.myrouteapp.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f44b.png?v=06c51928fc7" class="not-responsive emoji emoji-android emoji--wave" style="height:1.4em;width:auto;vertical-align:middle" title=":wave:" alt="👋" /></p>
<p dir="auto">A new website update is live, again with a lot of your forum topics in it <img src="https://forum.myrouteapp.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f4aa.png?v=06c51928fc7" class="not-responsive emoji emoji-android emoji--muscle" style="height:1.4em;width:auto;vertical-align:middle" title=":muscle:" alt="💪" /> Here's the short version.</p>
<h2>New</h2>
<p dir="auto"><img src="/assets/uploads/files/1794048650080-01-quick-menu.jpg" alt="01-quick-menu.jpg" class=" img-fluid img-markdown" width="1440" height="900" /></p>
<ul>
<li><strong>Keyboard shortcuts and a quick menu.</strong> Press ⌘K (Ctrl+K on Windows) for every page and command with its key. G then a letter goes to a page, ⌘S saves, / searches and ? shows them all. Single-key shortcuts can be turned off in Settings.</li>
</ul>
<p dir="auto"><img src="/assets/uploads/files/1794048654366-02-route-status.jpg" alt="02-route-status.jpg" class=" img-fluid img-markdown" width="1200" height="750" /></p>
<ul>
<li><strong>Route status and a note.</strong> Mark a route as Planning, To check or Ready and leave yourself a note. You see it in your library, in the planner and on the route page, a folder shows "3 of 7 ready", and you can sort and filter on it. Only people who can edit the route see it.</li>
</ul>
<p dir="auto"><img src="/assets/uploads/files/1794048658485-03-discover-categories.jpg" alt="03-discover-categories.jpg" class=" img-fluid img-markdown" width="1600" height="1000" /></p>
<ul>
<li><strong>Discover lists every category</strong>, grouped and each with its own pin. New: Historic, Museum, National park and Bureau de change. Supermarket is a chip in every travel mode.</li>
<li><strong>RouteXpert lines instead of a heatmap.</strong> Magenta lines, fainter where the library is crowded and full strength when you zoom in. Rest your mouse on a line (tap on a phone, long press on a tablet) to see which routes run there. A click still adds a waypoint.</li>
<li><strong>Trips: one stay for several nights.</strong> Nights in a row at one place show as one stay, with check-in, check-out and one hotel search. Set <strong>Nights here</strong> in the builder, add an address, or pick the spot on the map.</li>
<li><strong>Trips: route variants.</strong> A day can hold alternatives that stay out of the planned totals. The one you ride becomes the day's route.</li>
<li><strong>Arrive by.</strong> Give a route an arrival time and the planner tells you if you'll be late and when to leave instead.</li>
<li><strong>Avoid car trains</strong>, like the Tauern train, on every routing engine.</li>
<li><strong>Convert to routetrack</strong> straight from the ⋯ menu. No more export and import.</li>
<li><strong>Every point of your tracklog.</strong> Hover or click the line to read the time, speed and elevation of each recorded point, and step from point to point. Only you see this, on your own tracklogs.</li>
<li><strong>Put your tracklog photos in your own order</strong> by dragging them.</li>
<li><strong>Copy POIs</strong> to another group or to your favourites, also from a friend's shared group. A place's sheet in the planner has a star to add it to your favourites.</li>
<li><strong>Duplicate a waypoint</strong> from its panel or with C. The copy lands on the route without a new calculation.</li>
<li><strong>Vehicles</strong> can have private notes with phone numbers you can tap, and their own routing settings and day limit. Range and day limit follow the vehicle you pick.</li>
<li><strong>Filter a route's POIs by type</strong>, in the list and on the map.</li>
<li><strong>Find clubs and events by country</strong>, without knowing a name.</li>
<li><strong>Black</strong> as a route colour.</li>
<li><strong>Move on the map</strong> on a phone or tablet: move a waypoint with the crosshair instead of under your finger.</li>
<li><strong>The app manual is back</strong>, 29 chapters in all 8 languages, including CarPlay and Android Auto.</li>
</ul>
<h2>Improvements and changes</h2>
<ul>
<li>The padlock on the map is now the route lock: it shows on your own saved routes and one click locks or unlocks, like the menu. On a phone it's back, with the less used map buttons under a ⋯.</li>
<li>Street View opens looking along the road, in your direction of travel. On a phone on its side, map and Street View sit side by side.</li>
<li>On the Google maps the route stays on its road while you pan and zoom.</li>
<li>The waypoint panel fits on one screen, and Y, K and 1 to 9 set its type, colour and icon. The waypoint list has Select all.</li>
<li>Every search result has a button to add it as a waypoint in one click, and a pasted full address finds its street.</li>
<li><strong>Start route here</strong> asks whether to keep the direction or reverse it.</li>
<li>Waypoints on a hairpin no longer get a turn-around warning.</li>
<li>Tank range and missing vehicle sizes are now listed under Warnings.</li>
<li>Split into days and Trim keep the route's POIs. Converting a tracklog to a route puts the waypoints on the road you rode.</li>
<li>A file with both a route and a track asks which one to follow.</li>
<li>A POI can stay on the map when zoomed out, and a POI group can show its names.</li>
<li>Library: rows alternate in colour, Planner and Open work with a new tab, there's a link back to the folder you were in, the map has a fit button (F), and you can save a route in a folder a friend shared with you.</li>
<li>Compare can use routes friends shared with you, and has a slider for how see-through the lines are.</li>
<li>The heatmap can include uploaded tracklogs.</li>
<li>Unnamed waypoints are exported with their address instead of a number.</li>
<li>RouteXpert destinations start with your own country.</li>
<li>Planned vs ridden: a skipped stretch on a long straight road now counts as not ridden.</li>
<li>Links in club and event descriptions can be clicked.</li>
<li>A route locked in the classic app arrives locked.</li>
<li>A shared folder can be shared with up to 20 people.</li>
</ul>
<h2>Fixed</h2>
<ul>
<li>Along the route no longer crashes the planner when you use the 12-hour clock <img src="https://forum.myrouteapp.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f605.png?v=06c51928fc7" class="not-responsive emoji emoji-android emoji--sweat_smile" style="height:1.4em;width:auto;vertical-align:middle" title=":sweat_smile:" alt="😅" /></li>
<li>A link added to a trip write-up no longer disappears.</li>
<li>A trip that hasn't started no longer shows as Live, and older tracklogs are no longer added to it.</li>
<li>GPX files with POI details open in Garmin BaseCamp.</li>
<li>Your own folders no longer clash with folder names in a club.</li>
<li>Saving a copy of a route no longer marks the original as edited.</li>
<li>Imported classic departures and photos show the right local time, and names keep tags like <code>&lt;MT09&gt;</code>.</li>
<li>Fewer blank maps on browsers with a broken cache or graphics.</li>
<li>The elevation chart no longer covers dialogs, and a photo from a stay opens full screen.</li>
<li>Subscriptions: receipts no longer arrive twice, subscribing during a trial tells you when the first charge comes, and you no longer pay twice when one product includes another. Cancelling a period that wasn't paid ends it without a charge, and extra AI credits keep working after your plan ends.</li>
</ul>
<p dir="auto">That's it! Thanks again for all your feedback <img src="https://forum.myrouteapp.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f64f.png?v=06c51928fc7" class="not-responsive emoji emoji-android emoji--pray" style="height:1.4em;width:auto;vertical-align:middle" title=":pray:" alt="🙏" /></p>
<p dir="auto">Cheers,<br />
Corjan</p>
]]></description><link>https://forum.myrouteapp.com/topic/12429/website-update-keyboard-shortcuts-route-status-every-discover-category-and-more-of-your-feedback</link><generator>RSS for Node</generator><lastBuildDate>Sat, 07 Nov 2026 13:24:45 GMT</lastBuildDate><atom:link href="https://forum.myrouteapp.com/topic/12429.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 07 Nov 2026 10:51:40 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Website update - Keyboard shortcuts, route status, every Discover category and more of your feedback on Sat, 07 Nov 2026 11:31:32 GMT]]></title><description><![CDATA[<p dir="auto">Good job!</p>
]]></description><link>https://forum.myrouteapp.com/post/88170</link><guid isPermaLink="true">https://forum.myrouteapp.com/post/88170</guid><dc:creator><![CDATA[Òscar]]></dc:creator><pubDate>Sat, 07 Nov 2026 11:31:32 GMT</pubDate></item></channel></rss>
