<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Suggestions for improving your work with the library]]></title><description><![CDATA[<p dir="auto">I have imported all my routes and tracklogs (800+) into the new account. Due to the new possibilities in Routeplanner Next, you can make the folder hierarchy much flatter, which is why I have restructured my library from scratch. In the process, I noticed small but helpful improvement possibilities for some processes:</p>
<ol>
<li>
<p dir="auto">When you open the library, a map shows all routes and tracklogs at a glance. Very cool idea, because you can see at a glance where you have been, where there is an accumulation, and where you have never been before. With a large library, it would be helpful if you could see the name of the route / tracklog if you zoom in far enough on the map.</p>
</li>
<li>
<p dir="auto">If you move around the library a lot, it would speed up your work if you could open folders and see their contents without having to switch to the folder right away.</p>
</li>
<li>
<p dir="auto">When editing a large number of routes and tracklogs, it would be helpful if you could change certain settings for several routes/tracklogs at the same time. For example, routing settings, vehicle assignments and the like. Currently, you can select several routes/tracklogs at the same time, but only download, move or delete them.</p>
</li>
<li>
<p dir="auto">In the library, the routing setting is displayed with a vehicle icon for routes, but not for tracklogs. Yes, I know, you can filter by mode, if it is feasible, the display of the icon would still be helpful. This already works in the Android app.</p>
</li>
<li>
<p dir="auto">A folder cannot be moved to another folder if there is already a folder with the same name. Of course, this makes sense. However, the system does not give any feedback and you don't know at first why it doesn't work. Please include feedback or alternatively offer to assign a unique name, for example with the addition (1).</p>
</li>
<li>
<p dir="auto">The system allows you to move routes/tracklogs to the source folder, which doesn't make sense. It would be helpful if you don't get the source folder as a destination at all.</p>
</li>
<li>
<p dir="auto">Is there a backup function planned, by means of which you can download the entire library structure including its contents as a backup?</p>
</li>
</ol>
]]></description><link>https://forum.myrouteapp.com/topic/12400/suggestions-for-improving-your-work-with-the-library</link><generator>RSS for Node</generator><lastBuildDate>Fri, 06 Nov 2026 20:22:02 GMT</lastBuildDate><atom:link href="https://forum.myrouteapp.com/topic/12400.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 06 Nov 2026 17:59:02 GMT</pubDate><ttl>60</ttl></channel></rss>
