<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Battery drainage?]]></title><description><![CDATA[<p dir="auto">Hi,<br />
today I've done more or less 250 km navigating a route that I previously did, all with the new app, I started with 87% of battery on my phone (6000mAh), also had my Sena intercom connected and received one phone call of 5 minutes, no stops just once for refueling, and the phone was at 10% when there were still 80km for reaching my destiny.<br />
Maybe is my new phone, that I have to check how others apps are draining the battery, but just curiosity if it has happened to someone else or it's just me.<br />
As I say, I have just change phone two weeks ago, so I cannot compare the life of the battery between my old phone and the new one.<br />
Regards.</p>
]]></description><link>https://forum.myrouteapp.com/topic/12392/battery-drainage</link><generator>RSS for Node</generator><lastBuildDate>Fri, 06 Nov 2026 20:22:02 GMT</lastBuildDate><atom:link href="https://forum.myrouteapp.com/topic/12392.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 06 Nov 2026 15:47:21 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Battery drainage? on Fri, 06 Nov 2026 17:53:41 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/alexandre-marcel" aria-label="Profile: Alexandre-Marcel">@<bdi>Alexandre-Marcel</bdi></a> Its not really something I can answer as to what the battery drain really is as mine is always on charge when in use.</p>
<p dir="auto">I use quadlock wireless charger on the bike and in my car and wired charger and carplay in the wifes car</p>
<p dir="auto">I do know that if I leave my phone in my topbox still with the screen on at a stop the battery will drain by about 10% at a short stop.</p>
<p dir="auto">I would check your battery usage on the phone itself and see if there is anything else running in the background draining it too.</p>
]]></description><link>https://forum.myrouteapp.com/post/87971</link><guid isPermaLink="true">https://forum.myrouteapp.com/post/87971</guid><dc:creator><![CDATA[stuart marritt]]></dc:creator><pubDate>Fri, 06 Nov 2026 17:53:41 GMT</pubDate></item><item><title><![CDATA[Reply to Battery drainage? on Fri, 06 Nov 2026 17:36:09 GMT]]></title><description><![CDATA[<p dir="auto">Ja het verbruitkt veel stroom vooral als je met Carplay Android gebruikt,  als tip laad je telefoon tot 100% en zet er  gelijk een powerbank achter voordeel je hebt de hele dag volle stroom, ander voordeel is je telefoon  wordt niet warm  als er nog maar biv, 10  % op zit je powerbank  zal continu  bij laden tot je 100% en vooral met warme dagen  dat je problemen krigt en je telefoon af moet koelen.<br />
Gebruik sinds kort een ander navigatie systeem een Carpuride W702 Plus versie daar heb  je tefoon niet meer nodig, op de Carpuride installeer je de MRA myroute app, voor online verbinding gebruik je hotspot van je telefoon die kun je automatisch zetten zodra de Carpuride start gaat Hotspot ook aan, een  dag navigeren maar 20 % verbruikt althans  bij mij in de praktijk en tefoon wordt niet warm.<br />
En gebruik ook sinds kort een nieuwe  samsung A57 de oude was al 6 jaar oud.</p>
]]></description><link>https://forum.myrouteapp.com/post/87968</link><guid isPermaLink="true">https://forum.myrouteapp.com/post/87968</guid><dc:creator><![CDATA[Jeroen ekkel c]]></dc:creator><pubDate>Fri, 06 Nov 2026 17:36:09 GMT</pubDate></item><item><title><![CDATA[Reply to Battery drainage? on Fri, 06 Nov 2026 17:07:03 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/stuart-marritt" aria-label="Profile: stuart-marritt">@<bdi>stuart-marritt</bdi></a> It was three hours route more or less, as I said no stops, of course we are speaking on a bike, at two hours from the start it was at 10%, as I said one telephone call in, and no further use, no music, no radio, etc.....</p>
<p dir="auto">It just to know if some else has noticed something similar.</p>
]]></description><link>https://forum.myrouteapp.com/post/87967</link><guid isPermaLink="true">https://forum.myrouteapp.com/post/87967</guid><dc:creator><![CDATA[Alexandre Marcel]]></dc:creator><pubDate>Fri, 06 Nov 2026 17:07:03 GMT</pubDate></item><item><title><![CDATA[Reply to Battery drainage? on Fri, 06 Nov 2026 16:44:09 GMT]]></title><description><![CDATA[<p dir="auto">Its OK quoting 250km but if that took you 12 hours then I would say that's good for using a phone as the pain navigation.</p>
<p dir="auto">There is too many variables to say if the battery drain is good or not but for me I would never use any sort of navigation device without power applied to charge it</p>
]]></description><link>https://forum.myrouteapp.com/post/87951</link><guid isPermaLink="true">https://forum.myrouteapp.com/post/87951</guid><dc:creator><![CDATA[stuart marritt]]></dc:creator><pubDate>Fri, 06 Nov 2026 16:44:09 GMT</pubDate></item></channel></rss>
