<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Route-plan PDF: detailed map working, but some long directions are clipped]]></title><description><![CDATA[<p dir="auto">I have been testing the route-plan PDF in Safari on 20 October using a disposable test route.</p>
<p dir="auto">It was good to see the detailed street map render successfully this time. My earlier export had produced an outline instead, so this is a useful improvement for reviewing the route.</p>
<p dir="auto">The new PDF also retained the waypoint notes, icons and planned stop allowance.</p>
<p dir="auto">One remaining issue appeared in the directions: some long destination strings, particularly names separated by slashes, extend beyond the right-hand column and are cut off. Ordinary instructions generally wrap correctly.</p>
<p dir="auto">Could these longer destination strings be wrapped within the column, including where there are no spaces between the destinations?</p>
<p dir="auto">I have retained the example PDF and an image of the affected page if useful.</p>
]]></description><link>https://forum.myrouteapp.com/topic/11916/route-plan-pdf-detailed-map-working-but-some-long-directions-are-clipped</link><generator>RSS for Node</generator><lastBuildDate>Tue, 20 Oct 2026 20:01:15 GMT</lastBuildDate><atom:link href="https://forum.myrouteapp.com/topic/11916.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 20 Oct 2026 14:37:03 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Route-plan PDF: detailed map working, but some long directions are clipped on Tue, 20 Oct 2026 15:40:47 GMT]]></title><description><![CDATA[<p dir="auto">Yes, please share screenshots of the issue and a link to the route you used to create it. That's all I need <img src="https://forum.myrouteapp.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f642.png?v=06c51928fc7" class="not-responsive emoji emoji-android emoji--slightly_smiling_face" style="height:1.4em;width:auto;vertical-align:middle" title=":)" alt="🙂" /></p>
]]></description><link>https://forum.myrouteapp.com/post/85599</link><guid isPermaLink="true">https://forum.myrouteapp.com/post/85599</guid><dc:creator><![CDATA[Corjan Meijerink]]></dc:creator><pubDate>Tue, 20 Oct 2026 15:40:47 GMT</pubDate></item></channel></rss>
