<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Route line is not easy to follow on map]]></title><description><![CDATA[<p dir="auto">Hi,</p>
<p dir="auto">Trying some options inverting a route I found this kind of line:</p>
<p dir="auto"><img src="/assets/uploads/files/1791643933090-82a4703d-a89f-4a66-969e-2170e1c8d8bf-image.jpeg" alt="image.jpeg" class=" img-fluid img-markdown" width="1640" height="2208" /></p>
<p dir="auto">Yes, I know this is not normal and also happens on actual planner, but shows that when a route goes 2 or more times by same road is difficult to see what’s the real path to follow.</p>
<p dir="auto">While navigating, the app heads you to correct path, but difficult also if you only use visual (without hearing voice)</p>
<p dir="auto">Not expecting any fast update … only something to add into ToDo list.</p>
<p dir="auto">Regards</p>
]]></description><link>https://forum.myrouteapp.com/topic/11796/route-line-is-not-easy-to-follow-on-map</link><generator>RSS for Node</generator><lastBuildDate>Sat, 10 Oct 2026 17:20:59 GMT</lastBuildDate><atom:link href="https://forum.myrouteapp.com/topic/11796.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 10 Oct 2026 14:59:50 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Route line is not easy to follow on map on Sat, 10 Oct 2026 16:38:55 GMT]]></title><description><![CDATA[<p dir="auto">Aha, noted! <img src="https://forum.myrouteapp.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f609.png?v=06c51928fc7" class="not-responsive emoji emoji-android emoji--wink" style="height:1.4em;width:auto;vertical-align:middle" title=":wink:" alt="😉" /></p>
]]></description><link>https://forum.myrouteapp.com/post/84882</link><guid isPermaLink="true">https://forum.myrouteapp.com/post/84882</guid><dc:creator><![CDATA[Corjan Meijerink]]></dc:creator><pubDate>Sat, 10 Oct 2026 16:38:55 GMT</pubDate></item><item><title><![CDATA[Reply to Route line is not easy to follow on map on Sat, 10 Oct 2026 16:19:21 GMT]]></title><description><![CDATA[<p dir="auto">Perhaps I’m not using the best words here….</p>
<p dir="auto">Forget width, color and transparency. How easy is for you to follow the route? Can you guess what exit on roundabout is taken and order?</p>
<p dir="auto">That’s what I mean. And of course, this is not a critical issue, even is not a issue… only something to have in mind for a future if someone has time to expend on this: how to follow a track line going multiple times by same sector.</p>
<p dir="auto">Sorry if this was misunderstood</p>
]]></description><link>https://forum.myrouteapp.com/post/84881</link><guid isPermaLink="true">https://forum.myrouteapp.com/post/84881</guid><dc:creator><![CDATA[Lluis Arasanz]]></dc:creator><pubDate>Sat, 10 Oct 2026 16:19:21 GMT</pubDate></item><item><title><![CDATA[Reply to Route line is not easy to follow on map on Sat, 10 Oct 2026 15:46:47 GMT]]></title><description><![CDATA[<p dir="auto">I don't see the issue at all.<br />
You've chosen a certain width / color / transparency.<br />
Then this is something you can expect right?</p>
]]></description><link>https://forum.myrouteapp.com/post/84879</link><guid isPermaLink="true">https://forum.myrouteapp.com/post/84879</guid><dc:creator><![CDATA[Corjan Meijerink]]></dc:creator><pubDate>Sat, 10 Oct 2026 15:46:47 GMT</pubDate></item><item><title><![CDATA[Reply to Route line is not easy to follow on map on Sat, 10 Oct 2026 15:43:37 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/j%C3%B6rgen" aria-label="Profile: Jörgen">@<bdi>Jörgen</bdi></a><br />
Color and transparency only tells me how many times I pass a sector.</p>
<p dir="auto">First, this route I show is very bad and has no sense if you knows the road. But even for me is difficult to see what’s planner is telling me and why. There is no order or guide to follow line and I have to guess the route.</p>
<p dir="auto">Only to have in mind by developers. Perhaps they have a brilliant idea to dress up the route line.</p>
<p dir="auto">Regards,</p>
]]></description><link>https://forum.myrouteapp.com/post/84878</link><guid isPermaLink="true">https://forum.myrouteapp.com/post/84878</guid><dc:creator><![CDATA[Lluis Arasanz]]></dc:creator><pubDate>Sat, 10 Oct 2026 15:43:37 GMT</pubDate></item><item><title><![CDATA[Reply to Route line is not easy to follow on map on Sat, 10 Oct 2026 15:27:54 GMT]]></title><description><![CDATA[<p dir="auto">Try changing the color and/or transparency.</p>
]]></description><link>https://forum.myrouteapp.com/post/84876</link><guid isPermaLink="true">https://forum.myrouteapp.com/post/84876</guid><dc:creator><![CDATA[Jörgen]]></dc:creator><pubDate>Sat, 10 Oct 2026 15:27:54 GMT</pubDate></item></channel></rss>
