<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[How to import gpx - via Route or Route-Track?]]></title><description><![CDATA[<p dir="auto">I'm a new user on MRA, but I have many years of experience with BC.<br />
When I import a Google Maps *.gpx file with via points into MRA - what's the best way to do it?</p>
<ol>
<li>If I import it as a Route-Track and generate a route from the track using MRA:<br />
MRA generates many waypoints but no longer indicates the via points (which isn’t a problem since we can easily convert the few necessary waypoints into via points).</li>
<li>If I import it as a Route:<br />
MRA imports the GPX file correctly and displays the via points correctly, but I don’t see any waypoints that define the exact path of the route.</li>
</ol>
<p dir="auto">My question is:<br />
What is the best way to then - safely - follow the route using MRA Navigation Next (on android)?<br />
What happens if the route needs to be recalculated during navigation and there aren’t enough waypoints set?<br />
Will MRA Navigation Next calculate to the next Via point as there are no visible waypoints???<br />
To be on the safe side, should I manually set additional waypoints along the route when importing as a route?</p>
<p dir="auto">Many thanks for your feedback</p>
]]></description><link>https://forum.myrouteapp.com/topic/11712/how-to-import-gpx-via-route-or-route-track</link><generator>RSS for Node</generator><lastBuildDate>Thu, 01 Oct 2026 23:02:29 GMT</lastBuildDate><atom:link href="https://forum.myrouteapp.com/topic/11712.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 01 Oct 2026 18:18:06 GMT</pubDate><ttl>60</ttl></channel></rss>
