<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Suggestion: Fully lossless export/import format]]></title><description><![CDATA[<p dir="auto">I am increasingly using AI for enhancing my route maps - there is huge untapped potential out there.</p>
<p dir="auto">I have discovered that ChatGPT can work with a GPX 1.1 export from my MRA, make changes, and produce a file which imports quite well back into MRA. However, it loses a number of the proprietary attributes of an MRA map.</p>
<p dir="auto">For example, I can have AI locate a via point in the GPX and rewrite the title and commentary for that via point; but on re-import I lose the colour and icon for that via point.</p>
<p dir="auto">MRA has quite a rich internal waypoint model: type, icon, colour, name, pause, note and off-road status are all separate properties in the current Routeplanner. And GPX 1.1 includes an &lt;extensions&gt; element, inside which an application can store arbitrary XML in its own namespace. That means MyRoute-app could encode essentially all of its waypoint attributes while still producing a valid GPX 1.1 file.</p>
<p dir="auto">My suggestion is that there should be a “GPX 1.1 – MyRoute-app lossless” export format which would simultaneously be:</p>
<ul>
<li>a standards-compliant GPX readable by Garmin, TomTom and other applications;</li>
<li>a portable backup of an MRA route;</li>
<li>completely round-trippable back into MRA;</li>
<li>suitable for tools like the editing we can do with AI, without losing colours, settings, via-point classifications etc.</li>
</ul>
<p dir="auto">Ultimately there may be better solutions to integrate AI into MRA directly, or to build a special purpose GPT for map editing. But for the moment, I think the simplest and easiest approach would be a lossless export format.</p>
]]></description><link>https://forum.myrouteapp.com/topic/11600/suggestion-fully-lossless-export-import-format</link><generator>RSS for Node</generator><lastBuildDate>Sun, 13 Sep 2026 00:07:22 GMT</lastBuildDate><atom:link href="https://forum.myrouteapp.com/topic/11600.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 11 Sep 2026 06:31:18 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Suggestion: Fully lossless export/import format on Fri, 11 Sep 2026 06:48:46 GMT]]></title><description><![CDATA[<p dir="auto">Well that would be great.  But I hope if AI integration is under discussion then the developers will open some conversations about what we want from AI.  Or we could have a separate thread in this in the forum.  I’d be glad to contribute what I have been using AI for so far.</p>
<p dir="auto">And I still think a lossless export/re-import would be straightforward to implement and very valuable in the interim and probably long term.</p>
]]></description><link>https://forum.myrouteapp.com/post/83422</link><guid isPermaLink="true">https://forum.myrouteapp.com/post/83422</guid><dc:creator><![CDATA[Anonymouse]]></dc:creator><pubDate>Fri, 11 Sep 2026 06:48:46 GMT</pubDate></item><item><title><![CDATA[Reply to Suggestion: Fully lossless export/import format on Fri, 11 Sep 2026 06:40:26 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/anonymouse" aria-label="Profile: Anonymouse">@<bdi>Anonymouse</bdi></a> <a href="/post/83419">said</a>:</p>
</blockquote>
<blockquote>
</blockquote>
<p dir="auto">Apparently, MRA planner and the MRA Next navigator are currently going through updates to the next major versions. I can't imagine a scenario where the team would not take the opportunity to integrate AI into the tools. Let's see what they come up with.</p>
]]></description><link>https://forum.myrouteapp.com/post/83420</link><guid isPermaLink="true">https://forum.myrouteapp.com/post/83420</guid><dc:creator><![CDATA[Stevedo 6 0]]></dc:creator><pubDate>Fri, 11 Sep 2026 06:40:26 GMT</pubDate></item></channel></rss>
