<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Interesting behaviour on a pre-planned route that uses the same road in both directions]]></title><description><![CDATA[<p dir="auto">This is for information only and perhaps for others to relate this behaviour. I have sent the log files to the devs for investigation.<br />
I've attached the route below so others can review it and determine whether this was user error. On this occasion, I do not believe it was, but I'm happy to be proven wrong.<br />
<a href="https://www.myrouteapp.com/route/open/14195502" rel="nofollow ugc">https://www.myrouteapp.com/route/open/14195502</a></p>
<p dir="auto">Setup<br />
iPhone 13 Pro running the latest NN beta version<br />
Carpuride 702 (no issues observed with the device itself)<br />
Offline navigation enabled<br />
Automatic recalculation enabled (I don't normally use this, but it was enabled specifically for this test)<br />
Route as tracks enabled<br />
All maps downloaded and up to date</p>
<p dir="auto">The route was all good until I was travelling from waypoint 4 to waypoint 5.<br />
Along this section, I passed a junction on my right. This junction was part of the route later in the day, where I would make a left turn towards waypoint 12 when travelling in the opposite direction.<br />
As soon as I passed this junction while heading towards waypoint 5, NN recalculated the route and began insisting that I turn around and navigate to waypoint 12.<br />
I could not use Skip Waypoint, as doing so would have sent me to waypoint 13, which was not correct.<br />
As I knew the planned route, I ignored the instructions. NN continued trying to send me to waypoint 12 as I travelled through Hathersage.<br />
When I eventually stopped to investigate, I noticed that waypoints 6 to 11 were greyed out, as though they had already been visited, despite the fact that I had not yet reached them.<br />
To recover, I long-pressed waypoint 6 and selected it as my next point. NN then resumed navigation and I continued riding.</p>
<p dir="auto">After passing waypoint 7, NN then attempted to direct me to waypoint 11, which was now displayed as the next waypoint.<br />
Again, I ignored the instructions and continued along the planned route, passing waypoints 7 to 11 in sequence.<br />
Once I had reached waypoint 11, NN resumed normal operation and correctly navigated the remainder of the route (12 → 13 → 14, etc.).</p>
<p dir="auto">The same behaviour happened again on another section of the route where the outbound and return legs used the same road.<br />
After passing waypoint 17, I passed a junction on my right that I would use later when returning along the route.<br />
As soon as I passed this junction, NN repeatedly instructed me to turn around and navigate directly to waypoint 22.<br />
These instructions continued all the way into Macclesfield.<br />
I eventually stopped, long-pressed waypoint 18, and selected it. NN then immediately resumed the correct navigation instructions and followed the original planned route.</p>
]]></description><link>https://forum.myrouteapp.com/topic/11475/interesting-behaviour-on-a-pre-planned-route-that-uses-the-same-road-in-both-directions</link><generator>RSS for Node</generator><lastBuildDate>Sat, 15 Aug 2026 14:00:08 GMT</lastBuildDate><atom:link href="https://forum.myrouteapp.com/topic/11475.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 15 Aug 2026 11:42:53 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Interesting behaviour on a pre-planned route that uses the same road in both directions on Sat, 15 Aug 2026 13:45:43 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/paul69" aria-label="Profile: paul69">@<bdi>paul69</bdi></a> You are correct, it should not affect the route in the way that it has. The developers are looking into improving the algorithm for automatic skipping but it really isn't that easy. There are a lot of things to take into consideration when writing the new algorithm.</p>
]]></description><link>https://forum.myrouteapp.com/post/82383</link><guid isPermaLink="true">https://forum.myrouteapp.com/post/82383</guid><dc:creator><![CDATA[Nick Carthew]]></dc:creator><pubDate>Sat, 15 Aug 2026 13:45:43 GMT</pubDate></item><item><title><![CDATA[Reply to Interesting behaviour on a pre-planned route that uses the same road in both directions on Sat, 15 Aug 2026 13:11:29 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">hi <a class="plugin-mentions-user plugin-mentions-a" href="/user/hubert-thoring" aria-label="Profile: Hubert-Thoring">@<bdi>Hubert-Thoring</bdi></a> <a href="/post/82374">said</a>:</p>
<p dir="auto">So SP 5 closer to the junction maybe 100m, and for this SP 12 further away from the junction about 300m ... so it is perhaps better clear to the navigation system that SP 5 is closer than SP 12 is ..</p>
</blockquote>
<p dir="auto">SP 12 is 400m from the junction, as I've stated above, it would seem we need to ensure later SPs are further away than upcoming current ones if using same roads on a return journey. Does seem to be another thing we need to think about when planning routes.<br />
If this is the case then this thread will definitely give some tips to other users.</p>
<blockquote>
<p dir="auto">The same applies to SP 17, and certainly to SP 18 compared to SP 22.</p>
</blockquote>
<p dir="auto">Sp 17 is 900m away from junction, I do not need SP18 to be any closer as the route only really has one way to go.</p>
<blockquote>
<p dir="auto">When turning, it is always better to set a SP in 100m after the turn.</p>
</blockquote>
<p dir="auto">not sure why this is the case, or do you mean at least 100m, anyway, I am aware of the need to not place them close to a turn and I use this method in all my planning.</p>
]]></description><link>https://forum.myrouteapp.com/post/82379</link><guid isPermaLink="true">https://forum.myrouteapp.com/post/82379</guid><dc:creator><![CDATA[paul69]]></dc:creator><pubDate>Sat, 15 Aug 2026 13:11:29 GMT</pubDate></item><item><title><![CDATA[Reply to Interesting behaviour on a pre-planned route that uses the same road in both directions on Sat, 15 Aug 2026 13:00:17 GMT]]></title><description><![CDATA[<p dir="auto">hi <a class="plugin-mentions-user plugin-mentions-a" href="/user/nick-carthew" aria-label="Profile: Nick-Carthew">@<bdi>Nick-Carthew</bdi></a></p>
<p dir="auto">it was turned on, not sure why, TBF I usually have this turned off,<br />
but surely this should not affect the route in reality, why would the algorithm not pass waypoints in order, does seem strange behaviour.</p>
<p dir="auto">therefore, possibly when planning routes one will have to ensure that a later way/shaping point is not to close to a current one, another thing to think about jeez!!</p>
<p dir="auto">will see what today brings</p>
]]></description><link>https://forum.myrouteapp.com/post/82378</link><guid isPermaLink="true">https://forum.myrouteapp.com/post/82378</guid><dc:creator><![CDATA[paul69]]></dc:creator><pubDate>Sat, 15 Aug 2026 13:00:17 GMT</pubDate></item><item><title><![CDATA[Reply to Interesting behaviour on a pre-planned route that uses the same road in both directions on Sat, 15 Aug 2026 12:18:52 GMT]]></title><description><![CDATA[<p dir="auto">I think it's due to the automatic recalculation, which I usually turn off myself.</p>
<p dir="auto">I would recommend after the test as Nick has described also to adjust the WP and closer to the turn.</p>
<p dir="auto">So SP 5 closer to the junction maybe 100m, and for this SP 12 further away from the junction about 300m ... so it is perhaps better clear to the navigation system that SP 5 is closer than SP 12 is ...</p>
<p dir="auto">Have fun testing. VG <img src="https://forum.myrouteapp.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f44b.png?v=26d9aee90a1" class="not-responsive emoji emoji-android emoji--wave" style="height:23px;width:auto;vertical-align:middle" title="👋" alt="👋" /></p>
]]></description><link>https://forum.myrouteapp.com/post/82374</link><guid isPermaLink="true">https://forum.myrouteapp.com/post/82374</guid><dc:creator><![CDATA[Hubert Thoring]]></dc:creator><pubDate>Sat, 15 Aug 2026 12:18:52 GMT</pubDate></item><item><title><![CDATA[Reply to Interesting behaviour on a pre-planned route that uses the same road in both directions on Sat, 15 Aug 2026 12:07:41 GMT]]></title><description><![CDATA[<p dir="auto">Do you have <strong>Automatically skip waypoints</strong> on, it would help to trace the issue if you do have this selected to turn it off for your next test. Don't adjust the route, keep it exactly the same as the route you shared.</p>
]]></description><link>https://forum.myrouteapp.com/post/82373</link><guid isPermaLink="true">https://forum.myrouteapp.com/post/82373</guid><dc:creator><![CDATA[Nick Carthew]]></dc:creator><pubDate>Sat, 15 Aug 2026 12:07:41 GMT</pubDate></item><item><title><![CDATA[Reply to Interesting behaviour on a pre-planned route that uses the same road in both directions on Sat, 15 Aug 2026 11:59:30 GMT]]></title><description><![CDATA[<p dir="auto">I am going to ride this route again, with the iPhone set up the same way and I will also use my RT3, the settings will be the same for both, but RT3 with no internet.<br />
Will report back with my findings</p>
]]></description><link>https://forum.myrouteapp.com/post/82371</link><guid isPermaLink="true">https://forum.myrouteapp.com/post/82371</guid><dc:creator><![CDATA[paul69]]></dc:creator><pubDate>Sat, 15 Aug 2026 11:59:30 GMT</pubDate></item></channel></rss>
