<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Imported gpx File has errors when converted to Here map.]]></title><description><![CDATA[<p dir="auto">I have purchased on line a route for Morocco.<br />
I imported the gpx files for Garmin into my Route Planner.<br />
When i have My route app in Openstreet map mode the route shows up correctly. When I select Here Garmin map to save the modification I have done the waypoint are no longer in the correct position.<br />
Is their a solution to this problem?<br />
REgards,<br />
Simon</p>
]]></description><link>https://forum.myrouteapp.com/topic/11295/imported-gpx-file-has-errors-when-converted-to-here-map.</link><generator>RSS for Node</generator><lastBuildDate>Mon, 06 Jul 2026 12:27:36 GMT</lastBuildDate><atom:link href="https://forum.myrouteapp.com/topic/11295.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 05 Jul 2026 16:45:04 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Imported gpx File has errors when converted to Here map. on Mon, 06 Jul 2026 07:55:34 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/simon-james-hancock" aria-label="Profile: Simon-James-Hancock">@<bdi>Simon-James-Hancock</bdi></a> You might (temporarily) use an OSM map for Morocco in your Garmin.</p>
]]></description><link>https://forum.myrouteapp.com/post/80546</link><guid isPermaLink="true">https://forum.myrouteapp.com/post/80546</guid><dc:creator><![CDATA[Rob Veerman]]></dc:creator><pubDate>Mon, 06 Jul 2026 07:55:34 GMT</pubDate></item><item><title><![CDATA[Reply to Imported gpx File has errors when converted to Here map. on Mon, 06 Jul 2026 07:28:08 GMT]]></title><description><![CDATA[<p dir="auto">Yes<br />
Whilst having the OSM compare the route with Here. Make shure the Here line is exact like the OSM<br />
Then change the map to Here<br />
Done and have fun</p>
]]></description><link>https://forum.myrouteapp.com/post/80544</link><guid isPermaLink="true">https://forum.myrouteapp.com/post/80544</guid><dc:creator><![CDATA[Marinus van Deudekom]]></dc:creator><pubDate>Mon, 06 Jul 2026 07:28:08 GMT</pubDate></item></channel></rss>
