<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Adding a waypoint in the middle while navigating?]]></title><description><![CDATA[<p dir="auto">Hello, all!<br />
If at all possible, what is the procedure of adding a waypoint to the route i am navigating with the App on the fly?<br />
In other words, I just decided to go to a place (restaurant or hotel or whatever), that was not planned for.<br />
How can i set the new waypoint and navigate to it and then go back onto the planned route?<br />
Thanks!</p>
]]></description><link>https://forum.myrouteapp.com/topic/11294/adding-a-waypoint-in-the-middle-while-navigating</link><generator>RSS for Node</generator><lastBuildDate>Mon, 06 Jul 2026 09:50:09 GMT</lastBuildDate><atom:link href="https://forum.myrouteapp.com/topic/11294.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 06 Jul 2026 01:15:40 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Adding a waypoint in the middle while navigating? on Mon, 06 Jul 2026 05:00:44 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/lenny-o" aria-label="Profile: Lenny-O">@<bdi>Lenny-O</bdi></a> Yes, that’s right, the microphone really is very short. As I wear glasses, I have to bend the microphone to one side every time I put the helmet on, otherwise it gets caught on my glasses.</p>
<p dir="auto">Perhaps I’ll write to Sena about this as well… thanks for this hint.</p>
]]></description><link>https://forum.myrouteapp.com/post/80535</link><guid isPermaLink="true">https://forum.myrouteapp.com/post/80535</guid><dc:creator><![CDATA[Peter Zehentreiter]]></dc:creator><pubDate>Mon, 06 Jul 2026 05:00:44 GMT</pubDate></item><item><title><![CDATA[Reply to Adding a waypoint in the middle while navigating? on Mon, 06 Jul 2026 04:40:30 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/peter-zehentreiter" aria-label="Profile: Peter-Zehentreiter">@<bdi>Peter-Zehentreiter</bdi></a> Thank you!<br />
I forgot about that one....<br />
BTW, I see that you are using SLR-3. Mee too, and that short mic boom was soooo annoying to me.<br />
I spoke to Sena and they found a matching plug from another unit with a normal long boom and sent it to me for free. Life is good now! Just sayin..... <img src="https://forum.myrouteapp.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f60a.png?v=59d65072cd0" class="not-responsive emoji emoji-android emoji--blush" style="height:23px;width:auto;vertical-align:middle" title=":blush:" alt="😊" /></p>
]]></description><link>https://forum.myrouteapp.com/post/80534</link><guid isPermaLink="true">https://forum.myrouteapp.com/post/80534</guid><dc:creator><![CDATA[Lenny O]]></dc:creator><pubDate>Mon, 06 Jul 2026 04:40:30 GMT</pubDate></item><item><title><![CDATA[Reply to Adding a waypoint in the middle while navigating? on Mon, 06 Jul 2026 03:54:20 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/lenny-o" aria-label="Profile: Lenny-O">@<bdi>Lenny-O</bdi></a> Whilst navigating, tap the three dots in the bottom right-hand corner.</p>
<p dir="auto">Then select ‘Add waypoints’...</p>
<p dir="auto">You can either search for a location manually on the map and then add it to the route, or you can type, for example, ‘restaurant’ into the search field; this will display all the restaurants in the vicinity, and here too you can select one of your choice and then add it to the route.</p>
<p dir="auto">After visiting your new stop, you can continue on your way or return to the route; you may need to skip a waypoint (depending on where you’ve set your new stop).</p>
]]></description><link>https://forum.myrouteapp.com/post/80533</link><guid isPermaLink="true">https://forum.myrouteapp.com/post/80533</guid><dc:creator><![CDATA[Peter Zehentreiter]]></dc:creator><pubDate>Mon, 06 Jul 2026 03:54:20 GMT</pubDate></item></channel></rss>
