<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Allowing Highways]]></title><description><![CDATA[<p dir="auto">When I enter a destination on the MRA Android app and select the allow Highways option, the app will not navigate using highways (motorways as we call them in the UK. I have the Gold and MRA Navigation Next subscriptions.</p>
<p dir="auto">The allow Highways options will be toggled off again when I check. I toggle it on, app still won't navigate using highways and when I look at the routing options again, allow Highways will be toggled off.</p>
<p dir="auto">I really want to use satnav that will navigate via highways/motorways.</p>
]]></description><link>https://forum.myrouteapp.com/topic/11267/allowing-highways</link><generator>RSS for Node</generator><lastBuildDate>Thu, 02 Jul 2026 00:51:33 GMT</lastBuildDate><atom:link href="https://forum.myrouteapp.com/topic/11267.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 30 Jun 2026 17:33:05 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Allowing Highways on Wed, 01 Jul 2026 20:24:55 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mark-williams-5-0" aria-label="Profile: Mark-Williams-5-0">@<bdi>Mark-Williams-5-0</bdi></a> I think we may be talking at cross purposes or different things as this is not adding up at all correctly for me &amp; does not match what I see when I "enter a destination". You say.....</p>
<blockquote>
<p dir="auto">When I enter a destination on the MRA Android app and select the allow Highways option</p>
</blockquote>
<p dir="auto">For me this means a simple A &gt; B route from your location to a destination<br />
To do this I would select "Destination" from the route options draw,<br />
Search for &amp; then select my destination, followed by pressing the Navigate button &amp; my route options would be shown<br />
<img src="/assets/uploads/files/1782936974149-392084b1-2409-4e32-91d1-fc2f1a419ee8-image.jpeg" alt="392084b1-2409-4e32-91d1-fc2f1a419ee8-image.jpeg" class=" img-fluid img-markdown" /><br />
As you can see when select Leicester as my destination from west London it definitely allows me to use motorways / highways as it gives me the choice of routing via the M1 or M40<br />
Under "Avoidance options" the "Highways" button is the default green as an allowed road</p>
<p dir="auto">I think to help further you will need to explain your steps a bit more fully</p>
]]></description><link>https://forum.myrouteapp.com/post/80397</link><guid isPermaLink="true">https://forum.myrouteapp.com/post/80397</guid><dc:creator><![CDATA[Brian McG]]></dc:creator><pubDate>Wed, 01 Jul 2026 20:24:55 GMT</pubDate></item><item><title><![CDATA[Reply to Allowing Highways on Wed, 01 Jul 2026 01:17:52 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mark-williams-5-0" aria-label="Profile: Mark-Williams-5-0">@<bdi>Mark-Williams-5-0</bdi></a> Hi, Mark!<br />
If my understanding is correct, the "Destination" option is an implied "Scenic" route to various degrees that you can select. And om my Android it does not use Highways even when allowed.</p>
<p dir="auto">To just get to your destination (again could be controlled by avoidances), try using the option "MRA Routeplanner / Create new routes".<br />
It uses Highways then.</p>
]]></description><link>https://forum.myrouteapp.com/post/80366</link><guid isPermaLink="true">https://forum.myrouteapp.com/post/80366</guid><dc:creator><![CDATA[Lenny O]]></dc:creator><pubDate>Wed, 01 Jul 2026 01:17:52 GMT</pubDate></item><item><title><![CDATA[Reply to Allowing Highways on Tue, 30 Jun 2026 22:23:36 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/brian-mcg" aria-label="Profile: Brian-McG">@<bdi>Brian-McG</bdi></a> yes I even cleared the data and app cache. Also uninstalled reinstalled.</p>
<p dir="auto">Thanks for taking the time to reply.</p>
<p dir="auto">I sense I'll be using MRA for route planning for motorcycle tours but will have to stick with Waze if I just want navigation to a single destination. Shame as I paid for lifetime membership</p>
]]></description><link>https://forum.myrouteapp.com/post/80365</link><guid isPermaLink="true">https://forum.myrouteapp.com/post/80365</guid><dc:creator><![CDATA[Mark Williams 5 0]]></dc:creator><pubDate>Tue, 30 Jun 2026 22:23:36 GMT</pubDate></item><item><title><![CDATA[Reply to Allowing Highways on Tue, 30 Jun 2026 22:00:18 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mark-williams-5-0" aria-label="Profile: Mark-Williams-5-0">@<bdi>Mark-Williams-5-0</bdi></a> <a href="/post/80343">said</a>:<br />
</blockquote>
<p dir="auto">This is definitely not normal behaviour if your just selecting "Destination" from the route options draw in the app &amp; choosing a place to navigate too<br />
It sounds like the "Avoidance Option - Highways" setting has become fixed rather than selectable<br />
Have you tried toggling any of the other avoid options to see if they also reset?</p>
<p dir="auto">You could try force stopping the app to see if that resets anything or maybe try logging in/out of the app to see if that clears something</p>
]]></description><link>https://forum.myrouteapp.com/post/80363</link><guid isPermaLink="true">https://forum.myrouteapp.com/post/80363</guid><dc:creator><![CDATA[Brian McG]]></dc:creator><pubDate>Tue, 30 Jun 2026 22:00:18 GMT</pubDate></item><item><title><![CDATA[Reply to Allowing Highways on Tue, 30 Jun 2026 18:41:22 GMT]]></title><description><![CDATA[<p dir="auto">For use, I recommend reading the MRA manual. But to do this, you have to go to the web planner.</p>
<p dir="auto"><a href="https://www.myrouteapp.com/support" rel="nofollow ugc">https://www.myrouteapp.com/support</a></p>
<p dir="auto">The MRA Navi app routes on the highway if you want it, the settings may not contradict each other<img src="https://forum.myrouteapp.com/assets/plugins/nodebb-plugin-emoji/emoji/android/2705.png?v=59d65072cd0" class="not-responsive emoji emoji-android emoji--white_check_mark" style="height:23px;width:auto;vertical-align:middle" title="✅" alt="✅" /></p>
]]></description><link>https://forum.myrouteapp.com/post/80347</link><guid isPermaLink="true">https://forum.myrouteapp.com/post/80347</guid><dc:creator><![CDATA[Hubert Thoring]]></dc:creator><pubDate>Tue, 30 Jun 2026 18:41:22 GMT</pubDate></item></channel></rss>
