<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Account blocking issue]]></title><description><![CDATA[<p dir="auto">When an account is blocked due to an excessive number of devices, it would be very useful to be able to independently manage the number of devices associated with an account, as this isn't always done intentionally. Keeping the account blocked until the responsible staff unlocks it can take hours, causing significant disruption. Instead of blocking the account completely, the proposal, which would also save MyRouteApp staff time, is to allow access to the account, but without making it operational. Access would only be permitted to manage the devices independently and delete the files necessary to reactivate the account.</p>
<p dir="auto">Regards</p>
]]></description><link>https://forum.myrouteapp.com/topic/11176/account-blocking-issue</link><generator>RSS for Node</generator><lastBuildDate>Mon, 15 Jun 2026 16:18:12 GMT</lastBuildDate><atom:link href="https://forum.myrouteapp.com/topic/11176.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 15 Jun 2026 02:44:03 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Account blocking issue on Mon, 15 Jun 2026 15:31:37 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/con-hennekens" aria-label="Profile: con-hennekens">@<bdi>con-hennekens</bdi></a> , In my proposal, I put 2 conditions:</p>
<ul>
<li>Self managament of devices with a limit of 2 devices (as now)</li>
<li>Limit for devices change: Detect more device change than a limit (staff managed) to avoid multidevice self managing change.</li>
</ul>
<p dir="auto">In any case, no more than 2 devices allowed to run, no account blocking but  user self device deregister.</p>
<p dir="auto">We do not ask for more licenses, only a flexible way to change devices.</p>
<p dir="auto">About block, in my case it show that:</p>
<p dir="auto"><img src="/assets/uploads/files/1781537454849-8e08bef3-e9a0-4bc3-a5ed-0eff4223417a-image.jpeg" alt="8e08bef3-e9a0-4bc3-a5ed-0eff4223417a-image.jpeg" class=" img-fluid img-markdown" /></p>
<p dir="auto">So I can't logout and no use on any device</p>
<p dir="auto">Regards,</p>
]]></description><link>https://forum.myrouteapp.com/post/79519</link><guid isPermaLink="true">https://forum.myrouteapp.com/post/79519</guid><dc:creator><![CDATA[Lluis Arasanz]]></dc:creator><pubDate>Mon, 15 Jun 2026 15:31:37 GMT</pubDate></item><item><title><![CDATA[Reply to Account blocking issue on Mon, 15 Jun 2026 14:58:40 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/b0hd1" aria-label="Profile: b0hd1">@<bdi>b0hd1</bdi></a>, the problem with that is that it opens the possibility of "self-managing" many devices. <a class="plugin-mentions-user plugin-mentions-a" href="/user/brian-mcg" aria-label="Profile: brian-mcg">@<bdi>brian-mcg</bdi></a> is quite right in his assessment of devices per month...</p>
]]></description><link>https://forum.myrouteapp.com/post/79515</link><guid isPermaLink="true">https://forum.myrouteapp.com/post/79515</guid><dc:creator><![CDATA[Con Hennekens]]></dc:creator><pubDate>Mon, 15 Jun 2026 14:58:40 GMT</pubDate></item><item><title><![CDATA[Reply to Account blocking issue on Mon, 15 Jun 2026 13:06:20 GMT]]></title><description><![CDATA[<p dir="auto">I think it's important not to overlook Antonio's initial suggestion, which is the same one I made in another thread.<br />
We're not asking for more licenses or any kind of additional freedom. We're simply asking for self-management.<br />
Just as we can still use the route lab via the web when our account is locked, we should be able to access our account via the web and delete devices we've mistakenly added. That's self-management.<br />
More freedom for the user, less work for the staff. The same connectivity as before.<br />
In any case, this is a proposal that the staff should consider. They will decide if it is viable or possible.</p>
]]></description><link>https://forum.myrouteapp.com/post/79508</link><guid isPermaLink="true">https://forum.myrouteapp.com/post/79508</guid><dc:creator><![CDATA[b0hd1]]></dc:creator><pubDate>Mon, 15 Jun 2026 13:06:20 GMT</pubDate></item><item><title><![CDATA[Reply to Account blocking issue on Mon, 15 Jun 2026 12:48:41 GMT]]></title><description><![CDATA[<p dir="auto">i am still in process to find correct setup. iphone or android, tablet or phone. this had effect on my max devices.... not active but max devices. my account was also blocked because of my testing. also i did switch to newer phone.</p>
<p dir="auto">my solution was to contact support and ask to remove not used devices and give me a quote for 2 extra devices.</p>
<p dir="auto">I also use 1 android phone just to download gpx and put it in a android app. because i will not be allways online the app is more usefull for me.</p>
<p dir="auto">so i think current way works. if you have a blocked account contact support and there will be a solution.</p>
<p dir="auto">because i now know the limits i am extra carefull not to get a block.</p>
<p dir="auto">when my account was blocked still my first device did work. not the device i did wanted to use but i had a device.</p>
]]></description><link>https://forum.myrouteapp.com/post/79507</link><guid isPermaLink="true">https://forum.myrouteapp.com/post/79507</guid><dc:creator><![CDATA[Bouke Ent]]></dc:creator><pubDate>Mon, 15 Jun 2026 12:48:41 GMT</pubDate></item><item><title><![CDATA[Reply to Account blocking issue on Mon, 15 Jun 2026 11:55:54 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/lluis-arasanz" aria-label="Profile: Lluis-Arasanz">@<bdi>Lluis-Arasanz</bdi></a> sorry Luis but I think your suggestion could increase the costs for MRA<br />
at the moment they allow 2 devices to be logged in &amp; a 3rd device to be registered<br />
in your scenario it would still be also possible to have 2 logged in,<br />
but within one month you would allow a total of 4 registered devices, the 2 new + the 2 old</p>
<p dir="auto">We have to remember it is <strong>Here</strong> that are dictating the issue of licences per device &amp; I do not know what the Here terms are for the licence, if it is devices per month or devices per year</p>
<p dir="auto">If the licence is registered devices per month with your scenario of de-listing 2 devices per month MRA's costs could increase MRAs by 25%<br />
If it is registered devices per year you could be increasing the cost x24 if we all registered 2 new devices per month</p>
<p dir="auto">I am afraid that with MRA being generous they have dug themselves a bit of a hole, once people experience free the expectation is that more is also free, they are allowing us x3 devices when they should be allowing us x1</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/con-hennekens" aria-label="Profile: con-hennekens">@<bdi>con-hennekens</bdi></a> &amp; <a class="plugin-mentions-user plugin-mentions-a" href="/user/marinus-van-deudekom" aria-label="Profile: marinus-van-deudekom">@<bdi>marinus-van-deudekom</bdi></a> the update issue is an error on my end, nothing to worry about for MRA &amp; android updates</p>
]]></description><link>https://forum.myrouteapp.com/post/79505</link><guid isPermaLink="true">https://forum.myrouteapp.com/post/79505</guid><dc:creator><![CDATA[Brian McG]]></dc:creator><pubDate>Mon, 15 Jun 2026 11:55:54 GMT</pubDate></item><item><title><![CDATA[Reply to Account blocking issue on Mon, 15 Jun 2026 11:48:40 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/lluis-arasanz" aria-label="Profile: Lluis-Arasanz">@<bdi>Lluis-Arasanz</bdi></a> <a href="/post/79499">said</a>:</p>
<p dir="auto">Is not true, the block is for whole account, so "old" and "new" devices remains blocked. In case you gets blocked, you can't use MyRoute-app on any device.</p>
</blockquote>
<p dir="auto">Your statement contradicts the official one:<br />
<a href="https://forum.myrouteapp.com/post/74368">https://forum.myrouteapp.com/post/74368</a><br />
which says:</p>
<blockquote>
<p dir="auto">The change we made is that if you are blocked because of too many device, we only block your new devices. Meaning the original 2 devices you used will still be accessible.</p>
</blockquote>
<p dir="auto">It's just in this case from <a class="plugin-mentions-user plugin-mentions-a" href="/user/brian-mcg" aria-label="Profile: brian-mcg">@<bdi>brian-mcg</bdi></a>, where an OS system update is done and the designation of the phone seemingly changes, the old and the new one actually are the same, so they get blocked. That's worth investigating of course.</p>
]]></description><link>https://forum.myrouteapp.com/post/79503</link><guid isPermaLink="true">https://forum.myrouteapp.com/post/79503</guid><dc:creator><![CDATA[Con Hennekens]]></dc:creator><pubDate>Mon, 15 Jun 2026 11:48:40 GMT</pubDate></item><item><title><![CDATA[Reply to Account blocking issue on Mon, 15 Jun 2026 11:11:01 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/con-hennekens" aria-label="Profile: Con-Hennekens">@<bdi>Con-Hennekens</bdi></a></p>
<p dir="auto">To have in mind, we're speaking on 2 thinks, that could be good:</p>
<ul>
<li>User is allowed to "delist" old devices with a montly limit (maybe 2) of changes in a month. This helps user to change devices, but remains under control how many times can be done in a month. In any case, license cat be "more" than 2, so limits apply on same bases than now.</li>
<li>User can "forget" manually an old device to be inside 3 devices limit and 2 of them online. License is still under limit, and in case MRA wants to limit devices change, could be also a 2 devices remove limit in a month.</li>
</ul>
<p dir="auto">In any case, we're not speaking in neither make a higher license limit nor increase devices for a user. Simply, alloy user to "self manage" which devices are ok and which not.</p>
]]></description><link>https://forum.myrouteapp.com/post/79499</link><guid isPermaLink="true">https://forum.myrouteapp.com/post/79499</guid><dc:creator><![CDATA[Lluis Arasanz]]></dc:creator><pubDate>Mon, 15 Jun 2026 11:11:01 GMT</pubDate></item><item><title><![CDATA[Reply to Account blocking issue on Mon, 15 Jun 2026 11:09:49 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/con-hennekens" aria-label="Profile: Con-Hennekens">@<bdi>Con-Hennekens</bdi></a> I've updated my Android phone last week but lucky for me the phone wasn't seen as a new device. So I agree with <a class="plugin-mentions-user plugin-mentions-a" href="/user/con-hennekens" aria-label="Profile: con-hennekens">@<bdi>con-hennekens</bdi></a> that that's certainly worth investigation that</p>
]]></description><link>https://forum.myrouteapp.com/post/79498</link><guid isPermaLink="true">https://forum.myrouteapp.com/post/79498</guid><dc:creator><![CDATA[Marinus van Deudekom]]></dc:creator><pubDate>Mon, 15 Jun 2026 11:09:49 GMT</pubDate></item><item><title><![CDATA[Reply to Account blocking issue on Mon, 15 Jun 2026 09:56:26 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/brian-mcg" aria-label="Profile: Brian-McG">@<bdi>Brian-McG</bdi></a>, that's a fair view on it! Do I understand correctly that your Android devices were seen as new devices after a  Android version update? That might be something worth investigating. Just want to add, that only the excessive devices get blocked, not those that were within the limit. These Android version updates might throw things off...</p>
]]></description><link>https://forum.myrouteapp.com/post/79491</link><guid isPermaLink="true">https://forum.myrouteapp.com/post/79491</guid><dc:creator><![CDATA[Con Hennekens]]></dc:creator><pubDate>Mon, 15 Jun 2026 09:56:26 GMT</pubDate></item><item><title><![CDATA[Reply to Account blocking issue on Mon, 15 Jun 2026 09:34:56 GMT]]></title><description><![CDATA[<p dir="auto">Can sort of see the merit on both sides of this discussion</p>
<p dir="auto">I think it is generous of MRA to allow x2 devices per licence when I believe Here are charging per device,<br />
this does reduces MRA's margins, allowing x3 devices to get around the odd "error" is IMO very generous</p>
<p dir="auto">The device limit had not been an issue for me as I had managed to juggle between 3 devices without getting blocked<br />
Unfortunately today I updated x2 devices &amp; they have registered as new devices with MRA &amp; I am now blocked<br />
As suggested it would be nice to be able to resolve this personally but it is understandable why MRA want to control the number of registered devices &amp; costs</p>
<p dir="auto">I can only navigate with one device at a time but it is very useful to be able to have a backup so am grateful for the x2 device limit<br />
For me the current limit is a generous compromise that means I don't have to licence &amp; pay for every device</p>
]]></description><link>https://forum.myrouteapp.com/post/79485</link><guid isPermaLink="true">https://forum.myrouteapp.com/post/79485</guid><dc:creator><![CDATA[Brian McG]]></dc:creator><pubDate>Mon, 15 Jun 2026 09:34:56 GMT</pubDate></item><item><title><![CDATA[Reply to Account blocking issue on Mon, 15 Jun 2026 09:14:32 GMT]]></title><description><![CDATA[<p dir="auto">This kind of self-maintenance would enable the excessive use of devices. The limit is there to prevent that. In general a license gives you two devices. A third one will never block your account, it will merely make you delist another one. So enrolling a new device is no problem.</p>
]]></description><link>https://forum.myrouteapp.com/post/79480</link><guid isPermaLink="true">https://forum.myrouteapp.com/post/79480</guid><dc:creator><![CDATA[Con Hennekens]]></dc:creator><pubDate>Mon, 15 Jun 2026 09:14:32 GMT</pubDate></item><item><title><![CDATA[Reply to Account blocking issue on Mon, 15 Jun 2026 07:03:45 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/antonio-1e" aria-label="Profile: Antonio-1e">@<bdi>Antonio-1e</bdi></a> I completely agree. It's similar to what I requested in this message:</p>
<p dir="auto"><a href="https://forum.myrouteapp.com/topic/11170/autonomous-smartphone-management">https://forum.myrouteapp.com/topic/11170/autonomous-smartphone-management</a></p>
]]></description><link>https://forum.myrouteapp.com/post/79462</link><guid isPermaLink="true">https://forum.myrouteapp.com/post/79462</guid><dc:creator><![CDATA[b0hd1]]></dc:creator><pubDate>Mon, 15 Jun 2026 07:03:45 GMT</pubDate></item><item><title><![CDATA[Reply to Account blocking issue on Mon, 15 Jun 2026 06:56:18 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/nomko" aria-label="Profile: nomko">@<bdi>nomko</bdi></a></p>
<p dir="auto">Antonio is not speaking about not notification limit, only about managing personal devices to be under license limit.</p>
<p dir="auto">As I see, when you logout a existing device to configure a new one, the "old device" is still listed (yes logged out, bus is a "existing device")</p>
<p dir="auto">Sop, If you has "three devices listed" and only logged in in one of them, you are below license limit use... But if you add a ne device to replace one of those logged out, your account is blocked.</p>
<p dir="auto">Logged out devices are removed on monthly basis (as I read somewhere in this forum), so users can't do the work of "retire" old devices to allow new ones to be in "line".</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/antonio-1e" aria-label="Profile: antonio-1e">@<bdi>antonio-1e</bdi></a> ask for a "user action" to remove those devices, so he can do manual actions to change old devices.</p>
<p dir="auto">Of course, is staff decide to limit number of changes in a month, it could be also a good way to avoid unlimited changes.</p>
<p dir="auto">Is only a proposal, and developers can take (or not) suggestions into account.</p>
]]></description><link>https://forum.myrouteapp.com/post/79460</link><guid isPermaLink="true">https://forum.myrouteapp.com/post/79460</guid><dc:creator><![CDATA[Lluis Arasanz]]></dc:creator><pubDate>Mon, 15 Jun 2026 06:56:18 GMT</pubDate></item><item><title><![CDATA[Reply to Account blocking issue on Mon, 15 Jun 2026 05:21:07 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/antonio-1e" aria-label="Profile: antonio-1e">@<bdi>antonio-1e</bdi></a><br />
I understand your issue and frustration. But there is also a user's responsibility to check if they are not crossing the max limit of devices logged in into MRA.</p>
<p dir="auto">You can check it for yourself:</p>
<ol>
<li>
<p dir="auto">In the MRA Next app tap on your profile photo/picture top right.<br />
<img src="/assets/uploads/files/1781500732271-f095a00a-51ea-499d-98ee-acb5f5bcb826-image.jpeg" alt="f095a00a-51ea-499d-98ee-acb5f5bcb826-image.jpeg" class=" img-fluid img-markdown" /></p>
</li>
<li>
<p dir="auto">In the settingsmenu that appears, scroll down to the bottom and look for a line saying "My devices"<br />
<img src="/assets/uploads/files/1781500814006-f0c5f31e-c06a-4e12-84ff-9da3b5b23cc9-image.jpeg" alt="f0c5f31e-c06a-4e12-84ff-9da3b5b23cc9-image.jpeg" class=" img-fluid img-markdown" /></p>
</li>
<li>
<p dir="auto">Check the amount of devices and disconnect those who are no longer needed/required<br />
<img src="/assets/uploads/files/1781500861206-ae5e5fd2-9f2d-4156-b5f7-7a1a77836998-image.jpeg" alt="ae5e5fd2-9f2d-4156-b5f7-7a1a77836998-image.jpeg" class=" img-fluid img-markdown" /></p>
</li>
</ol>
]]></description><link>https://forum.myrouteapp.com/post/79451</link><guid isPermaLink="true">https://forum.myrouteapp.com/post/79451</guid><dc:creator><![CDATA[nomko]]></dc:creator><pubDate>Mon, 15 Jun 2026 05:21:07 GMT</pubDate></item></channel></rss>
