<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Avoid roadblocks - how does it work?]]></title><description><![CDATA[<p dir="auto">Hi,<br />
I am trying to understand how this new feature works or how to enable something.</p>
<p dir="auto">For me it looks like (in the moment) that only "Select distance" is working.</p>
<p dir="auto">I should mention, though, that I'm only trying it here at home right now, so the conditions might not be right.</p>
<p dir="auto">If I use "Select distance" the next upcoming kilometers will be newly calculated.<br />
If I use "Select waypoint" or manual I get an error message and there is now new route.<br />
But I am not sure how to use it correctly.</p>
<p dir="auto">What is the correct way for select WP and/or manually?</p>
<p dir="auto"><img src="/assets/uploads/files/1780940666821-screenshot_20260608-162556.png" alt="Screenshot_20260608-162556.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.myrouteapp.com/topic/11115/avoid-roadblocks-how-does-it-work</link><generator>RSS for Node</generator><lastBuildDate>Tue, 09 Jun 2026 12:41:39 GMT</lastBuildDate><atom:link href="https://forum.myrouteapp.com/topic/11115.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 08 Jun 2026 17:45:29 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Avoid roadblocks - how does it work? on Tue, 09 Jun 2026 08:48:56 GMT]]></title><description><![CDATA[<p dir="auto">I can confirm there is a maximum implemented for how long a detour can be. I don't know how much, but based on your findings it looks to be 30 km. But I really don't know. I can imagine that is too short, especially in mountainesque areas.</p>
]]></description><link>https://forum.myrouteapp.com/post/79082</link><guid isPermaLink="true">https://forum.myrouteapp.com/post/79082</guid><dc:creator><![CDATA[Con Hennekens]]></dc:creator><pubDate>Tue, 09 Jun 2026 08:48:56 GMT</pubDate></item><item><title><![CDATA[Reply to Avoid roadblocks - how does it work? on Tue, 09 Jun 2026 07:53:08 GMT]]></title><description><![CDATA[<p dir="auto">Morning,</p>
<p dir="auto">I played around a bit more with the new feature and found the following:</p>
<p dir="auto">Here the test route: <a href="https://www.myrouteapp.com/de/social/route/13652390?mode=share" rel="nofollow ugc">https://www.myrouteapp.com/de/social/route/13652390?mode=share</a></p>
<p dir="auto">I started the route and the navigation, after the first announcement, I open the menu and select “Roadblocks.”<br />
<strong>Then select Waypoint</strong><br />
From the WP list, select WP2 - ok works from start point (my current position)<br />
WP3 - ok works<br />
WP4 - ok works<br />
WP5 - Not ok error</p>
<p dir="auto"><strong>Next - Select distance</strong><br />
5 km - ok<br />
20 km - ok<br />
25 km - ok<br />
30 km - Not ok error</p>
<p dir="auto"><strong>Next - Manually</strong><br />
Start WP3 - End WP4 - ok<br />
Start WP4 - End WP5 - ok<br />
Start WP5 - End WP6 - ok<br />
Start WP5 - End WP7 - Not ok, error<br />
Start WP5 - End WP8 - Not ok, error</p>
<p dir="auto">The error comes because <strong>(may be too far or too many WPs)</strong></p>
]]></description><link>https://forum.myrouteapp.com/post/79077</link><guid isPermaLink="true">https://forum.myrouteapp.com/post/79077</guid><dc:creator><![CDATA[Jörgen]]></dc:creator><pubDate>Tue, 09 Jun 2026 07:53:08 GMT</pubDate></item></channel></rss>
