<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[After coffee, MRA does not continue from where we left off.]]></title><description><![CDATA[<p dir="auto">When going for a coffe and powering the bike (and my 7"RiderNav R7M) down, MRA is kept alive on my phone,but when starting up the bike the navigation does not continue by joining the nearest point on the route, but it tries to send me back to where the biginning of the track was.</p>
<p dir="auto">I need to change any MRA setting on my phone, or what?</p>
<p dir="auto">Regards,<br />
Frank Koster</p>
]]></description><link>https://forum.myrouteapp.com/topic/11032/after-coffee-mra-does-not-continue-from-where-we-left-off.</link><generator>RSS for Node</generator><lastBuildDate>Fri, 29 May 2026 14:49:41 GMT</lastBuildDate><atom:link href="https://forum.myrouteapp.com/topic/11032.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 28 May 2026 21:32:58 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to After coffee, MRA does not continue from where we left off. on Fri, 29 May 2026 13:30:58 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/frank-hosper" aria-label="Profile: Frank-Hosper">@<bdi>Frank-Hosper</bdi></a> AndroidAuto</p>
]]></description><link>https://forum.myrouteapp.com/post/78361</link><guid isPermaLink="true">https://forum.myrouteapp.com/post/78361</guid><dc:creator><![CDATA[Nick Carthew]]></dc:creator><pubDate>Fri, 29 May 2026 13:30:58 GMT</pubDate></item><item><title><![CDATA[Reply to After coffee, MRA does not continue from where we left off. on Fri, 29 May 2026 12:16:21 GMT]]></title><description><![CDATA[<p dir="auto">what do you mean by AA connection?</p>
]]></description><link>https://forum.myrouteapp.com/post/78360</link><guid isPermaLink="true">https://forum.myrouteapp.com/post/78360</guid><dc:creator><![CDATA[Frank Hosper]]></dc:creator><pubDate>Fri, 29 May 2026 12:16:21 GMT</pubDate></item><item><title><![CDATA[Reply to After coffee, MRA does not continue from where we left off. on Fri, 29 May 2026 06:46:37 GMT]]></title><description><![CDATA[<p dir="auto">The simple solution is to when you leave your bike and your AA connection with the phone is lost, just close down AA. When you will continue your ride just start AA again. In my case this did the trick!<br />
The problem is de lost connection. It will not connect in the right way when you return to your bike.<br />
Another solution will be to leave your phone at your bike. Than the connection does not get lost!</p>
]]></description><link>https://forum.myrouteapp.com/post/78334</link><guid isPermaLink="true">https://forum.myrouteapp.com/post/78334</guid><dc:creator><![CDATA[white.mouse]]></dc:creator><pubDate>Fri, 29 May 2026 06:46:37 GMT</pubDate></item><item><title><![CDATA[Reply to After coffee, MRA does not continue from where we left off. on Fri, 29 May 2026 05:49:40 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/frank-hosper" aria-label="Profile: Frank-Hosper">@<bdi>Frank-Hosper</bdi></a> The simplest solution is to check the next point before starting the route, and if it tries to send you back to the previous point, skip it manually. It's simple, practical, and fast. Sometimes algorithms can be a bit unpredictable.</p>
<p dir="auto">Regards</p>
]]></description><link>https://forum.myrouteapp.com/post/78328</link><guid isPermaLink="true">https://forum.myrouteapp.com/post/78328</guid><dc:creator><![CDATA[b0hd1]]></dc:creator><pubDate>Fri, 29 May 2026 05:49:40 GMT</pubDate></item><item><title><![CDATA[Reply to After coffee, MRA does not continue from where we left off. on Fri, 29 May 2026 05:45:40 GMT]]></title><description><![CDATA[<p dir="auto">Hi Frank,<br />
That's a known error/bug/inconvenience of MRA.<br />
If you use the search bar you can find similar topics. Perhaps you can find the solution in 1 of those topics.</p>
]]></description><link>https://forum.myrouteapp.com/post/78327</link><guid isPermaLink="true">https://forum.myrouteapp.com/post/78327</guid><dc:creator><![CDATA[nomko]]></dc:creator><pubDate>Fri, 29 May 2026 05:45:40 GMT</pubDate></item></channel></rss>
