<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Add option for output audio as HFP instead of A2DP]]></title><description><![CDATA[<p dir="auto">I would like to see in future an option, which can be enabled, that MyRoute-app can output it's audio via HFP instead of A2DP.</p>
<p dir="auto">The reason for this is, that Sena Intercom headsets are able to do audio multitasking by overlay both audio sources. But this only works, if you have multiple devices, and one uses A2DP and one HFP. Garmin does this with using HFP. Kurviger App and Locus both also implemented such option to enable.</p>
<p dir="auto">The scenario here is for example: Device 1 paired as Smartphone is your regular daily devices for phone and music (for example), while Device 2 is a Smartphone with MRA used only for navigation. If one devices uses HFP and other A2DP, the device outputing with A2DP will be lowered in audio level and HFP audio source will be overlayed played (you can her both audio streams simultaneously). If both devices use A2DP, then the first device will be silenced as long the second device plays its audio and no audio multitasking overlay happens. This is a hard limitation in Sena Intercom headsets.</p>
<p dir="auto">Based on <a href="https://forum.locusmap.eu/index.php?topic=6242.0" rel="nofollow ugc">https://forum.locusmap.eu/index.php?topic=6242.0</a>, this doesn't look hard to implement?</p>
]]></description><link>https://forum.myrouteapp.com/topic/10708/add-option-for-output-audio-as-hfp-instead-of-a2dp</link><generator>RSS for Node</generator><lastBuildDate>Sun, 05 Apr 2026 22:46:58 GMT</lastBuildDate><atom:link href="https://forum.myrouteapp.com/topic/10708.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 04 Apr 2026 21:06:37 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Add option for output audio as HFP instead of A2DP on Sun, 05 Apr 2026 09:47:44 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/j%C3%B6rgen">@<bdi>Jörgen</bdi></a> said in <a href="/post/75797">Add option for output audio as HFP instead of A2DP</a>:</p>
<blockquote>
<p dir="auto">However, when I establish a Bluetooth connection with my passengers, I no longer receive navigation instructions.</p>
</blockquote>
<p dir="auto">You mean Intercom with passengers? Did you enabled Multitasking Audio via Sena app? You need to do it, as its disabled per default.</p>
]]></description><link>https://forum.myrouteapp.com/post/75799</link><guid isPermaLink="true">https://forum.myrouteapp.com/post/75799</guid><dc:creator><![CDATA[ConiKost]]></dc:creator><pubDate>Sun, 05 Apr 2026 09:47:44 GMT</pubDate></item><item><title><![CDATA[Reply to Add option for output audio as HFP instead of A2DP on Sun, 05 Apr 2026 08:27:40 GMT]]></title><description><![CDATA[<p dir="auto">I’m currently looking into this issue as well, and my setup is similar.<br />
I use my iPhone as my main phone and as Device 1 in the Sena.<br />
The tablet with MRA is paired with the Sena as Phone 2.<br />
So far, this works very well. MRA works, and so do other functions on the tablet.<br />
However, when I establish a Bluetooth connection with my passengers, I no longer receive navigation instructions.<br />
In the Sena group, I’ve been advised to pair the tablet as a navigation device. That might then work with this overlay as well.<br />
I haven’t tried that yet.<br />
I don’t yet know how this would affect a mesh connection either.</p>
]]></description><link>https://forum.myrouteapp.com/post/75797</link><guid isPermaLink="true">https://forum.myrouteapp.com/post/75797</guid><dc:creator><![CDATA[Jörgen]]></dc:creator><pubDate>Sun, 05 Apr 2026 08:27:40 GMT</pubDate></item></channel></rss>
